| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
Hi, i'm new here, and i was milling today when i encountered "runtime error 9 - subscript out of range". I am cutting 3/4" mdf, and pathed on mastercam X. The mastercam file previews perfectly on mastercam, and the exported NC files preview perfectly on the Techno CNC interface as well. I am able to preprocess and preview it on the Techno CNC interface. However, once i click on the start button, i get the error and the interface crashes. These are simple contour cuts and pocket cuts. Will someone please help me??? Thanks! |
Greetings. I am certainly not a pro, but I had the same error and found your post while looking for a solution. I got in touch with my Techno rep and he suggested that the tool number I had specified (from my MasterCAM tool library) was too high for Techno to deal with. I changed the number off the tool from 235 to 4 and the programs ran fine. I had changed most of the programs from within MasterCAM, but the one that I missed I changed with the editor in the Techno interface and that worked as well. He also thought there may have been too much extra subset information (in the parentheses) in the programs and suggested deleting that from the .nc files. I did not have to do that, but it is a second option if changing the tool number does not work. Good luck. Chuck |
As stated above, I've gotten this error and have found that it refers to the tool numbering in Mastercam, it is not a problem with the interface. I'm using X3... When I start a new Machine Group, I have an option under Properties >> Tool Settings >> Toolpath Configuration to check "Assign Tool Numbers Sequentially." If not checked, the system may assign a high tool number like #232 (don't know why???). Checking the box, causes tool numbering to start at #1 and it then increases sequentially. If I forget to check that box for a new mach group, I'll get the "Subscript out of range" error when using the interface. Hope that helps. |
| mori seiki mv junior "jog rset" error | Arsonist | General Metal Working Machines | 10 | 03-24-2010 06:45 PM |
| BOSS8 "+Z OVERFLOW" error message | jonny | Bridgeport and Hardinge Mills | 11 | 05-29-2008 04:12 AM |
| Help! Leadwell VMC "605: Interlock error"?? | SRT Mike | General Metal Working Machines | 1 | 01-02-2007 08:06 AM |
| mazak t1 universal "error 124 n" | dohcom | Mazak, Mitsubishi, Mazatrol | 0 | 11-23-2006 07:25 AM |
