Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 02-21-2007, 01:36 AM
hotponyshoes is on a distinguished road
Using a pc as a dro device..
First, sorry if this in in the wrong place.
Second,
We have finally got a workshop setup, we have a large 4-axis mill, a large lathe and a small lathe.
We have fitted cooling / fluid to them all and now we are looking to add some sort of digital read-out to them.
It would be nice to convert (especially the mill) to cnc but we are wondering what the best way to get started is?
Having looked on ebay, you can get a 3-axis read-out box for around ukŁ350, the thing that was drawing us to this one is that it has a pcd function, as we will be making car hubs this would be really usefull.
We don't really want to spend 1k+ on 3 of these units though and we also dont want to have to keep unplugging scales to only use one readout box either.
So, can anybody point us in the direction of any information on using a normal pc for the dro display?
We have a stack of cheep moniters (15"svga) and figured we could just fix one to the wall above each machine and run them from a multi-output video card on one central pc,
Our plan being to buy the scales for each machine (unless you can diy these too!) so we need to find some sort of box that can let the scales 'talk' to the pc and also some software to display the info on the computer. software that includes a pcd function if possible!
We also figured that once you had this it would be fairly simple to add cnc to the system - just add motors to the axis's and the computer could move x until x reads whatever..
Is this possible or more to the point is anybody doing it?
Thanks!
Old 02-21-2007, 02:10 AM
Karl_T's Avatar
Karl_T is on a distinguished road
May be worth a read.
http://www.shumatech.com/
Old 02-21-2007, 08:24 AM
Al_The_Man's Avatar
This has been posted several times before. http://www.lindsayengraving.com/othe...rests/dro.html
Old 02-21-2007, 08:32 AM
WayneHill's Avatar
WayneHill is on a distinguished road
removed by wayne.
Wayne Hill
www.codemangler.com
Old 02-21-2007, 09:58 AM
Zumba is on a distinguished road
Interesting link with the rotary encoders. But with a "central PC" idea, you're going to have to walk back and forth constantly zeroing your axes.
modbus device Drew Machines running Mach Software 14 02-11-2007 01:59 PM
Need Foam Device Made HIGHtungsten Employment Opportunity 0 09-20-2006 12:08 AM
I want to write printer driver for my plotter device. bunalmis OpenSource Software 8 02-28-2006 12:31 PM
Boss 6 Unknown device DaveinUK Bridgeport and Hardinge Mills 3 01-17-2006 03:32 AM
Commercial Artsy Craftsy Device gregh Printing, Scanners, Vinyl cutting and Plotters 0 10-31-2005 08:25 AM
