Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 02-13-2007, 06:42 PM
dogstar is on a distinguished road
Help needed DynaPath 20 Tool-radius-compensation
I thought I understood how C1, C2 & C0 worked...but something's not working for me.
So I made up a test. Below is the very simple prgm I made; it draws a circle , going CW, with a 1" in radius....that's all. Tool diameter, T1, is set in table to 0.5". E1 IS THE FIXTURE offset. I mounted a pencil in my drill chuck and ran the program.
I EXPECTED that if Compensation is C0 (OFF), then the pencil will draw a circle going CW of exactly 2" diameter....and it does. Good so far....
I EXPECTED that if Compensation is C1 (left)... then the pencil will draw a circle of 2.25" diameter, accounting for the 1/4" radius of the tool....but it does not. In fact the pencil follows the same path...1" radius...no compensation.
I EXPECTED that if Compensation is C2 (right) in line N003... then the pencil will draw a CW circle of 1.75" diameter, accounting for the 1/4" radius of the tool....but it does not. The pencil again follows the same path...1" radius...no compensation.
If I change the tool diameter to, say....75" diam...I get the same result. If I make the tool diameter .125" ...same result: no comp.
I hope someone can help get me. Thanks in advance.
N001 (9) M00 T1 E1
N002 (0) X0 Y0 Z0
N003 (2) A0 B360 D0 C1 R1 F25
N004 (9) M30
Radius compensation in Mach3 kayakman Mach Mill 20 12-06-2006 10:43 AM
Tool compensation bg_izio CamSoft Products 3 04-27-2006 10:43 AM
Tool Radius Compensation davidmb General CAM Discussion 5 07-29-2005 09:16 AM
Radius compensation in Mach2? MrBean General CAM Discussion 3 03-19-2005 07:49 AM
