Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 02-09-2007, 11:25 PM
wddanie is on a distinguished road
drip feed Anilam Crusader II?
Has anyone been successful drip feeding an Anilam Crusader II controller? I have one on a 1985 Lagun knee mill, and recently got it running with the good troubleshooting advice of others on this forum. Now I have a 3000 line program I want to run on it, but I understand that it can only hold a 999 line long program. I'd appreciate any advice about how to make this happen.
Thanks,
Doug Danielson
Atlanta
Old 02-16-2007, 08:38 PM
bdambacher@dsl. is on a distinguished road
it is possible but tricky. you need some special mcodes and a servo enable relay that would disable the servos while the exchange of information happens. not easy and messy.
Crusader II is dead !
long live the crus II...
Old 02-23-2007, 11:07 AM
psevin is on a distinguished road
DNC to Anilam
I have some notes on this I could fax to you. If you'd like them, email your fax number to me at psevin at ovationengineering.com
Paul Sevin - Ovation Engineering, Inc.
http://www.ovationengineering.com
Old 04-03-2007, 12:10 PM
jslynn is on a distinguished road
drip feed crusader
The crusader ii can have 6000+ steps. The step size of the control varies from 2 bits to 13 bits. This means the program size can change.
A program event of one axis is 5 bits and an event with 3 axis move is 13.
Later PC cards had page memory that doubled the events steps you can store. The limit was 9000 events as this was reserved for canned cycle programming. You can see the canned cycle program by searching for event 9000 and stepping. If you are single stepping through a program with canned cycle, in aux 1900 (step by event mode) you will also see the canned cycle stuff.
If you use the subroutines you can usually reduce the program size.
good luck. maybe It will load without a problem
JOHN
jsl@specialmachines.com
Anilam Crusader 2 DNC/RS-232 CRAZYRICH Post Processor Files 6 10-11-2011 12:54 AM
V20 With Anilam Crusader II harvard5 BobCad-Cam 5 09-23-2011 08:55 PM
Anilam Crusader II - Crusader 2 Training DVDs Mike Mattera Product Announcements & Manufacturer News 2 07-08-2007 10:31 PM
Anilam Crusader 2 Help porsche1220 General CNC (Mill and Lathe) Control Software (NC) 3 04-09-2006 01:37 PM
Anilam Crusader 2 Help plascom General Metal Working Machines 4 01-23-2005 05:10 PM
