Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 02-03-2007, 11:32 AM
N4NV is on a distinguished road
Tach vs encoder
I see some machines use a tach and others use an encoder to determine position. I understand how the encoder works. How does the tach work to determine machine position?
Vince
Old 02-03-2007, 11:37 AM
Al_The_Man's Avatar
A DC tach is seldom used now, it was used principally with velocity style drives, as part of an inner loop feedback loop to the drive only, the outer loop was the encoder to control.
A DC tach was never used as a positioning device for CNC servo's.
Its DC ouput depends on rpm not position.
Old 02-03-2007, 11:53 AM
Tach
I have a machine with Servo Dynamics SD1525 servo drives and SEM permanent magnet servomotors. Looking at the wiring diagram it looks like it has only tach input. How would the machine know its position? The machine is a Yamazen CNC knee mill.
Vince
Old 02-03-2007, 11:56 AM
Al_The_Man's Avatar
The Drives use the tach as I mentioned, but the controller needs feedback from an encoder of some kind, you should have one on a separate shaft or even linear scales, if it is not on the motor, On SEM they sometimes add an encoder on the end of the Tach shaft?
Old 02-03-2007, 12:00 PM
Tach
I will have to look closer at the motor to see if it has an encoder. On the drive there is no encoder input, but there is a differential input, would this be for the encoder?
Vince
Old 02-03-2007, 12:03 PM
Al_The_Man's Avatar
No, the drives do not have an encoder input, the encoder is used by the controller only.
If you are looking at the drive manual only, it may not show the motor encoder, even though there is one mounted.
Old 02-03-2007, 03:41 PM
One of Many is on a distinguished road
To clarify a bit of what Al is stating.
The Tach puts out a voltage(I.E. a small DC generator) of say 7v per 1000rpm. These are very linear( on the order of .2%) in relation to axis/motor velocity(speed). The servo amp uses this to track how fast it needs to turn to keep up with the commanded position and resulting path via a closed loop in relation to position feedback of the encoder pulses at the motion controller. The +/- 10v analog signal from the motion control is controlling the servo amp output, in sync with the feed rate and path profile, so one does not over run the other. There can be several pots on the servo amp to tune the systems electronically with the mechanical influences of the machine itself.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 02-03-2007, 05:12 PM
I got into the contol cabinet and the Allen Bradley 8400MP controller and found the encoder inputs. Now it makes more sense. BTW, does anyone know who works on the 8400 contollers or how I can get around the password protection. The guy who I bought the mill from sold it for someone else and he does not know the password.
Vince
Tach kit mark c General Electronics Discussion 5 10-12-2007 05:50 PM
Encoder to DC tach circuit Wanted. Al_The_Man General Electronics Discussion 20 07-07-2007 11:33 AM
Q: CNC 7x14 with replacement motor and tach Deviant Mini Lathe 5 02-15-2006 12:03 AM
diy tach swarfmacdaddy General Electronics Discussion 6 01-29-2006 12:57 PM
Cheap tach Zephrant General Electronics Discussion 1 06-05-2003 03:11 PM
