Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 01-15-2007, 10:43 AM
*Registered User*
hien100881 is on a distinguished road
Spindle enable alarm Fanuc OTB
Hi any body
My machine is Tongil control Fanuc OTB alrm 998 Rom parity , I set old parameter X & Z axis run Jog & Zero oke but can't run spindle , can't set Diagnostic , If you can please help me
Old 01-15-2007, 10:56 AM
jackson's Avatar
jackson is on a distinguished road
"just asking" but what about a door interlock
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
Old 01-18-2007, 04:47 PM
debco99 is on a distinguished road
If you have a model a ) control (without a graphics board) the memory board contains 5 chips 2 of those are the Eprom's for the ladder and 2 of them are the proms for the firmware and the remaining one is for the servo.
There should be a code on the screen (hex value) indicating where in the prom's the error is coming from.
Having just gone thru this with a customer last week what I did was order the 3 rom's and a new memory board to make sure the problem was solved.
You need to make sure you have a complete back-up of parameters and part programs.
Check to make sure all the chips are properly seated in the sockets, there are a total of 5 in sockets.
I doubt clearing the memory will help you at all. If the control wont boot at all normally and you dont have a backup or a hard copy from the mtb you should be prepared for a challange.
Good Luck
Old 01-21-2007, 02:29 AM
*Registered User*
Thank you
