| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
#14
Hi There, The board did send a copy of your post by email and I thought I'd reply to try and offer a bit of guidance re: the parts of the ebook that should be most helpful to you. You are correct in thinking that 2.5D or Parts type work is best addressed using spline or vector modelling / editing in gmax. I think Chapter 4 of the ebook is most relevant to the type of work you are looking at, particularly the 'Parts and Layout' and 'Toolpaths' sections of the chapter. As you have a 4 axis setup, the 3D spline building parts of the 'Toolpaths' section might be helpful. Toolpath processing examples in chapter 7 will probably also be helpful. gmax and CNC_Toolkit excel at this type of work and for many parts you need only create a simple 'outline' drawing, from which you can then generate a multipass toolpath to whatever depth your tooling can cut with a user specified number of passes. If gmax seems a bit heavy for the work you are doing, a useful and less complex alternative might be found in the FREE CamBam beta software discussed in chapter 8. CamBam does excel at things like region based clearance paths and outline cutting and can be a lot more 'automatic' than gmax although it's editing tools are not as powerful. ebook content related to image editing and mesh deformation etc will not be required in the type of work you describe. The ebook starts with these aspects of CNC as, like yourself, many people do at least have some familiarity with image editing. hope this helps Danny
__________________ What one man can do another man can do.. BitMaps to Models, 3D2Relief, tutorials and FREE CNC Software http://cnc4free.org Last edited by yohudi; 08-23-2010 at 05:36 AM. |
#15
| Thanks for the guidance and especially for the effort you have put into this project of yours. And I am sorry for calling you "David" in my first post. You usually just go by yohudi. I have also spent many thousands of hours compiling free information for the benefit of others. see my Hubpage at : http://hubpages.com/hub/Copyright-free-aircraft-plans ![]() I removed the post because I could not remember my specific questions and I FINALLY got the help files and tutorials for G-max. I do remember a few things that were giving me a lot of trouble: 1...In chapter four on page fourteen fig. 20 you show the 2.5D snap as green and active. MY copy does not look the same it has a "3" on that button and when I hover over it it is identified as "3D Snap Toggle". I can see no sign of a 2.5D toggle anywhere??!? 2...Can Cam Bam handle a fourth axis? (My guess is "no") "ebook content related to image editing and mesh deformation etc will not be required in the type of work you describe." 3...These techniques although not normally useful for regular machining might prove valuable when creating particularly detailed surfaces where the design most logically starts from a 2D source. Photo engraving or texturizing leaps to mind. Am I thinking along the right lines? 4...You intended your tutorial to be used AFTER the user had already gone through the G-max tutorial from turbosquid correct? (I have not as yet) Just so you know I have downloaded ALL of your "essential" freeware WITH whatever documentation it comes with and even 3D Exploration 1.5 with BRL_CAD as they might come in handy for file conversion purposes. You mention a few times a G-max support site that is no longer available, do you still have the URL? Perhaps enough of the site was "crawled" to have a useful amount of information available at archive.org using "The Wayback Machine" If it does have some useful information I could copy it and make it available on a Yahoo Group or Hubpage. It would be nice to rescue such a resource from digital purgatory. Thanks again. I can see where someone who has a system like mine might spend as much as he did on the machine for software and end up with far LESS capability than your compilation seems to provide. Did you ever finish your second tutorial? I believe it was basically ALL about turning 2D bitmaps into 3D files suitable for bas relief style engraving yes? Gary B in BC struggling to teach himself CNC for free with some help from yohudi. ![]()
#16
Hi there, many thanks for your positive and supportive comments..... I'll try and help with a few things your post raised below... and I'll also add your Aircraft plans site to the links page at cnc4free.org next update. Re: your questions.
This button has a few options associated with it. I think there is mention of the functions on the gmax GUI page. and i also think it's covered in the 'Fundamentals' sections of chapter 4. The button toggles snap on and off and also displays the type of snap that is active. When it shows a '3' this means 3D snap is active. If you left-click and hold on this button a slide out appears with a '3', '2.5' and '2' option. '2.5' = 2,5D snap, '2' = 2D snap. If you right-click the button a 'Snaps and Grids' options panel will appear, this allows further customisation of 'Snap' options..
Of itself CamBam cannot address 4th axis toolpathing. CamBam does have a 'Convert Toolpath to Geometry' function. This means any CamBam path you might want to apply using a 4th axis can be exported as .DXF. gmax imports 2D and 3D .DXF files and thereafter gmax tools / CNC_Toolkit can be applied to the imported toolpath to exploit it using indexed or continuous 4 axis machining.
When I stated these techiques are not required for 'the type of work you describe' this is of course a bit of a generalization. There are no hard and fast 'rules' re: the use of the ebook methods... If you can think of a way to apply them in 2.5D work then by all means go for it. Texturisation could be one option and / or 'Photo-Carving'. CamBam is particularly useful for 3 axis 'Photo-carving'
I think it's probably more helpful to use the ebook in conjunction with the gmax helpfile. This is available as a separate download at 'Turbosquid'. The gmax helpfile is comprehensive and generally has detailed examples re: use of gmax tools/ functions and options. What the ebook adds to this is exploitation of the tools specifically aimed at CNC applications.
I think the support site you mention is probably 'David H Smiths' site that is sadly no longer online. I think some of the site content can still be found via 'cached pages. I do have some of the pages saved to hard-drive myself. This site was VERY useful re things like file export and gmax on linux... I'm not sure that it would be OK to just put up 'David H Smiths' work but I will try and see if it is available at archive.org as you suggest.. I think it would be OK to link to it if this is the case and I wouldn't have a problem doing that from cnc4fre.org or as you say perhaps you could do it from Yahoo. It was a great loss when it disappeared.
Again many thanks for your positive and insightful comments. I think there is a great deal of CNC work easily acheived using FREE tools and I was surprised that consolidated information re: FREE software was not widely available.. This was the primary motivation for creating the ebook. I hope you find both the ebook and other resources at cnc4free.org to be of use in your CNC endeavours. Regards Danny (aka Yohudi).
__________________ What one man can do another man can do.. BitMaps to Models, 3D2Relief, tutorials and FREE CNC Software http://cnc4free.org |
#17
Thanks again! Once you mentioned holding the left mouse button down on the snap button it all became clear! It's the only button down there that acts that way. http://web.archive.org/web/*/davidhsmith.net/* Has THOUSANDS of pages archived! I even managed to DOWNLOAD md3exp.zip from his "essentials" page!! Now I can directly export .MD3 files! WOW not bad for a "dead" website! I LOVE The Wayback Machine! I see no problem posting this information since he made it available for free. perhaps Mr. Smith has passed on. There is more there than I would like to re-format and post but the above link will get you to any and all of it. I believe I am ready for a marathon study session which will end with a completed part! Thank you again and again Danny! Gary B in BC getting ready to CNC |
#18
![]() Re MD3exp.zip... this is actually a redundant addon. gmax 1.2 has inbuilt support for mD3 export... I'll check if the link to 3DExploration1.5 is active there.. as it's a lot faster than Lithunwrap for MD£ conversion. all the best and thanks again for the complimetary remarks... and for the wayback machine info / link TTFN Danny
