| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
| I don't have that specific information, but I believe it is on the same table as the current tool called, standby tool, magazine index position ect... From the manual: Press "return", "F4" System, "30" (F menu), "input", "PMC", "PMCPRM", "DATA" Actually I thought it was on "G-Data" after "data", I would have to check the machine to be sure. The manual does not list G-data but has been known to be wrong before. Dale |
| Thanks Dale, I found it the other day. You are right, it is in the G-data table. I'm adding more tools to the magazine today so by this afternoon I should be ready to change the data in the table and hope it works. Thanks again, Kirk
__________________ Kirk |
| For adding tools pockets to the chain, be aware that Hitachi may have other places you need to change the value... When they integrating their software in/with the 16i they did some strange things. Some options you have to enable in the normal Fanuc way as well as for the Hitachi software. So, the number in the G-data table. This alone may let it work with the larger chain, but not access the added pockets. The Fanuc option for the given number of tools. The Fanuc option for the number of tool offsets. |
| If so your probably going to have to trace it down by looking thru the ladder logic. From past experience, most problems end up being a switch/sensor or some action not being completed. Dale |
| Hi Dpuch Thank you for your answer very much. we checked all sensors and switches which were well operation. At present, machine is working with memory mode, tape mode , DNC and Edit regulations very well. we don't know how to use Ladder Logic, pls help us how to use it. Thank a lots, Best regards, Dung VP |
