Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 01-08-2007, 03:41 AM
wjfiles is on a distinguished road
No Z Axis
I am testing a new home built router and have not yet hooked up the X Axis.
How can I run a program and manually operate the Z.
Would I edit the G Code and delete reference to the Z and somehow tell it to stop until I have set the Z Axis.
On second thoughts could I mark the reference to the Z in the G Code so that it is ignored or skipped. this would enable me to reinstate the code when I hook up the Z.
The reason for this is that I am not yet competent with Mach3 setup and I don't want to dig holes in the floor of my workshop.
The More I Learn The Less I Seem To Know
Old 01-08-2007, 03:49 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
use an optional stop or m0 before every z move
Old 01-08-2007, 03:56 AM
Thanks for the reply. However I am allowed one more dumb question.
Do I leave the original code in place and if so will it skip to the next instruction.
What is the difference between M0 and M00.
Make that two dumb questions.
Maybe a small example would help.
thanks in advance
Old 01-08-2007, 04:06 AM
dertsap's Avatar
Gold Member
there is no difference between the two , if you leave out the zero's the file size is shorter g01 g1 , m00 m0 , i'm in the habit of leaving out the zero's because some of our cnc's have small memory and some of our programs are quite long , plus if your hand programming it saves a lot of needless finger punching
before every z move add a m0
g0g90g54x0y0
m0
g43h1z1.
Old 01-08-2007, 04:27 AM
Thanks Dertsap your blood is worth bottling.
Old 01-08-2007, 05:05 AM
dertsap's Avatar
Gold Member
suppose it's ready to bottle it's already been pickled
