| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
| Does anyone recommend any FREE communication software for a PC to RS232 port? Eventually this company that I am doing work for will have some but I just need something in the short term. Thanks in advance for any help! Independent CNC Programmer http://www.ctcn.net/~3kings/index.html |
| www.Cadem.com... Free.. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Last edited by Al_The_Man; 12-03-2006 at 03:51 PM. |
I guess from your email that you want to use the serrial port (RS232) to communicate with something. On your Windows system use the Hyperterminal program. Start it with START > PROGRAMS > ACCESSORIES > COMMUNICATIONS > HYPERTERMINAL. It works. I have used for years. |
| Easy DNC software is a good communication software and you can download trial package from www.dncxp.com |
| I am using HyperTerminal for RS-232 PC to CNC communication. I am experiencing a few gliches that I did not expect; one being that I can send to the CNC but when I recieve to the PC I either get a garbaged up text file or what appears to be to many CR's in the file. Anyone else have this problem before? This is on a Fanuc 21-TB control. Anyone sure on the parameter setting I should have? Thanks. |
| I have found Hyperterminal is not as good as the old Terminal program that came with Win3.1, if you can get a copy of that it is much better. Otherwise see here http://www.cadem.com/ncnet/ncnet_dncdetails-41.htm Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| I am using Win 2000 HyperTerminal for a Fanuc 21-T and Mazak M-Plus. On the M-Plus we are having issues where the link will not disconnect and continue to try sending files and sometimes will not overwrite an existing file when sending from CNC to the PC. Anyone else have the same issues? On the Fanuc I can get the file to look good in HyperTerminal screen but when I open in Notepad looks like garbage or too many indents (CR's) in the file. Not a problem until I try sending back to the CNC and alarms out the buffer. HELP! |
#12
__________________ Matt San Diego, Ca ___ o o o_ [l_,[_____], l---L - □lllllll□- ( )_) ( )_)--)_) (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
