Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
  #13   Ban this user!
Old 11-24-2006, 06:14 PM
Originally Posted by JerryFlyGuy View Post
So infact they aren't absolute but rather..'Close position encoders'
Jerry
Every encoder is a 'close position encoder' just some are closerer than others.
Old 11-24-2006, 06:32 PM
Al_The_Man's Avatar
There are basically two types of 'absolute' encoders being used, common one has a track for every bit value, usually starts at 10bits & up, commonly used on robots, the other retains the information by battery backup.
There was in fact a post today in the Fanuc forum, where someone lost the battery on his absolute encoders (battery backed up quadrature) . These have to be re-referenced when first initiallized, after that the machine does not have to be referenced on power up.
The 10~16 bit coded type do not require battery backup.
The Non-battery quadrature encoder has to be first referenced in the controller and then the absolute position is known as long as it is kept powered.
