Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 11-13-2006, 01:30 PM
webcruiser8 is on a distinguished road
calculate total path length
I wonder if someone could suggest a software that can calculate
the total length of the machine path for waterjet cutting. We got
dxf file, but we want to estimate the total time of cutting so we
can estimate the cost of cutting a part. Please help.
Many thanks
Old 11-13-2006, 01:43 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Many thanks
http://www.cncsimulator.com/
or use mach3 with lazycam to simulate the run and it will show the time it takes, you just set up the program as if connected to machine ie: all parameters.
Old 11-13-2006, 01:55 PM
Thanks for your reply, the simulation is 1 to 1 realtime isn't it?
If a parts takes 2 hours to cut, use the simulation to calculate
the time is a little slow. Wish to have a software to look at the
dxf or even G-code to add all the length and estimate the machine time.
Old 11-13-2006, 02:01 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
You can use NcPlot ( www.ncplot.com ) Click on "Tools/Show Part Info" Not to mention the program is just GREAT!!
Free trial period also.
Old 11-13-2006, 02:10 PM
joecnc2006's Avatar
www.joescnc.com
No they are not real rime, well mach 3 is not i use it and one hour run shows up within a couple of mins with estimate.
