Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 10-11-2006, 08:07 AM
shadybacon is on a distinguished road
cnc controller problem
Hi Everyone,
Has anyone experienced this problem before? I was cutting yesterday at a constant depth (z axis was not moving) and the z axis dropped 1". I checked for a mechanical failure and the coupling and screw were fine. Next, I wanted to test and see if I could get the same problem again so I removed the tool and reset the z axis and reran my toolpath; The first part of the path sends the head to y22x78; there was a knock and the head travelled only in the y direction not the x but the software (wincnc) showed the head at x78.
Has anyone experienced a similar problem? Can anyone advise me as to where to look to solve this problem? Any help will be appreciated as I am in the middle of a job.
Jon
Actaeon Custom Woodworks, LLC
