Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 10-08-2006, 10:26 AM
littlebear is on a distinguished road
wiring steppers/ gecko 201
I am building an inlay cutting machine. I have four wire stepper motors NEMA 43, and I am using Quickstep3 software and Gecko stepper drivers on X nad Y . The booklet I got with the Quickstep says you should need no resistor for these motors. I am runnig 30 volt power supply to the steppers and the stepper motor has a resistance of 2.5 ohms. I have all other connections made, have configured my printer 25 pin port to see voltage change with direction toggle in the software, but the motors still do not move. My third axis is a servo drive unit. and I have the g320 servo driver for it, it also will not move. Big Question, I know, but any help out there?
