Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 09-11-2006, 09:27 AM
steedspeed is on a distinguished road
Tool change on Fanuc OT
Ok! I'm new to lathes so go easy on me! When I program a toolchange the turret rapids over to the chuck. Quite scary when all I asked it to do was change tools! Any idea why this would happen? Control is Fanuc OT
Old 09-11-2006, 11:08 AM
Al_The_Man's Avatar
It depends on how the machine tool builder set it up, generally the turret will go to the home or extreme end of the carriage (Z) and out in the X.
What is the present command you are using? It may need a routine call or special M coded call before.
This is where the OEM manual is good.
Old 09-11-2006, 01:01 PM
I just type T1010 or whatever tool number I want and it rushes over to the chuck!
I'm sure it is something simple but in spite of extensive milling experience I am totally new to lathes.
Old 09-11-2006, 01:20 PM
Al_The_Man's Avatar
What is the machine? as Fanuc do not write the tool change sequence so it would be machine specific, someone here may have the same model.
Old 09-11-2006, 02:51 PM
It is a Takisawa.
Old 09-11-2006, 03:37 PM
Problem solved! Told it to grab tool 100 and it stopped the scary moves!
