Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 09-05-2006, 10:30 PM
Kiwi is on a distinguished road
Question G41 to G40 Milling
When G41 is active, is it possible to cancel with G40 and move to the point which is the centre of the tool without the tool moving from the last G41 command?
Also the reverse senerio where G40 is active and then activate G41 and move to the point which is tangent to the cutter diameter and the tool dosen't move?
Old 09-05-2006, 10:40 PM
wmyerscnc is on a distinguished road
The simple answer is no. In almost all controls, a linear move must be executed during application or cancelation of compensation.
To get a little more complicated: If you program your path at the center of the tool, and only use the compensation for tool wear or deflection, the move required can be very small. I always recommend using this method.
If you are programming with workpiece dimensions and using compensation to adjust for the tool radius, you will see some odd things from time to time.
Good judgement comes from experience. Experience comes from bad judgement...
Old 09-06-2006, 02:01 AM
wmyercnc
As the tool path has moved from G41 offset to G40 tool centre, is this not considered a linear movement.
If this dosen't meet the requirements will .001" be enough?
