Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 09-02-2006, 09:03 PM
t305100 is on a distinguished road
Another stupid question?
Does anyone have any opinions on what is the best CAD/CAM software for a CNC milling machine? I am building a 3 axis gantry type machine driven by steppers. The motors will be controlled by Pic List "Linistepper" drive boards.
I intend to be milling PCBs as well as nonferrous metals & plastics. Both the metals & plastics I expect to be fairly complex 3 dimensional shapes.
I will be using a pentium based PC running XP. Cost is an issue, but getting a good package is more important than outright cost.
Your advice would be most appreciated.
Tony.
Old 09-02-2006, 09:08 PM
*Registered*
lakeside is on a distinguished road
there are many out there and every one will tell you the one they use is the best. How much do you want to spend.
Old 09-03-2006, 12:31 AM
You are so right every package is brilliant according to someone. However, I am looking for something capable of more than 3 axis (for future projects), has a reasonably intuitive interface, easy to get started with (if not to master), is accurate & not full of bugs!
I would like to spend no more than £250.00, but I could stretch that if it really made a difference.
Thanks for your interest & hopefully help.
Regards,
Tony.
Old 09-03-2006, 12:56 AM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
There are very few in that price range. The only 3Axis software I can suggest is BobCAD-CAM V21. Mike and I are both users of this software. He has been using it since V19 and myself since V17. It is reasonably priced for 3 Axis work but isn't a really good 4 Axis Application. I'm afraid that for what you have to spend on software, BobCAD may be your only choice. There may be something else but I don't know what.
Try a free demo of BobCAD to see if you like it. Here is a Link to the BobCAD-CAM Forum if you have any questions about the software. You can also call Chad Clark. I deal with him when buying software and he knows how to use BCC and will answer your questions. 877-262-2231 Ext. 124
http://216.117.147.20/bobcadsupport/forums/index.php
www.bobcad.com
Good Luck in your search
BTW: Welcome to CNC Zone
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 09-03-2006, 02:37 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
easy enough to use a 3 axis software such as bobcad and edit the 4 axis move , unless of coarse you planning on doing some funky 4 axis machining
Old 09-03-2006, 04:02 AM
Thanks for your views, I will look into "Bobcad" (I am, even now looking into Bobcad). Do you know of any other packages to compare it to, the Mach series of CNC software for instance?
Many thanks again,
Tony.
Old 09-03-2006, 05:04 AM
tobyaxis's Avatar
Moderator
Many thanks again,
Tony.
BTW: There is no such thing as a "Stupid Question". All questions are valid to the individual.
BCC is a Big Bang for the Buck 3 Axis Software that is why I have been using it since V17, V19, V20, and now V21. Check out the post V22 in the BobCad Forum here in the Zone. It has not been released as of yet, but will Kick Butt when it is. You could most likely get it for $500.00 U.S. Which is a sweeet deal.
Toby D.
Schwarzwald
Old 09-03-2006, 08:24 AM
ger21's Avatar
Many thanks again,
Tony.
Mach3 does not come with a 3D CAM package. It's basically a machine controller with some 2D CAM capability.
Check out MeshCAM at www.meshcam.com
Old 09-03-2006, 10:00 AM
*Registered*
one question that you need to answer is are you looking for a cad/cam for 3d drawing as well as cam or are you just looking for cam
Old 09-03-2006, 10:16 AM
dertsap's Avatar
Gold Member
i agree in this post ,
but dude a couple of the people that i supervise , i find it incredible what they can ask me in a day
Old 09-03-2006, 10:51 AM
ger21's Avatar
I'll second, third and fourth that.
  #12   Ban this user!
Old 09-03-2006, 02:17 PM
I find that if you ask a "Stupid question" you invariably start to get some answers. However, now that I have had some questions asked back, I will try to frame my question in a more targeted manor.
I hope that you will bear with me;
I have a computer, Pentium running XP.
I am about to take delivery of a 3 axis gantry type Milling machine.
I intend to use “Linistepper” stepper drive boards as featured on the “PIC List” (open source project).
I do not have a mechanical CAD package, so I’m open to suggestions.
I have an EDA package including pcb CAD outputting Gerber files (it will output in about 20 different formats inc DFX, ORCAD, PCAD)
I require to be able to mill pcbs for prototype work.
I require to be able to create medium complexity components in either plastics or nonferrous metals.
So, what do I need? As I see it;
1) Connection between computer & drive boards, Printer port or USB?
2) Mechanical Cad package (would Bobcad if the bill)?
3) Control software (I am considering Mach 3 from ArtSoft) from PC via 2"whatever" to stepper drive boards?
So I open it up to the experts, what do you suggest?
Many thanks in advance for your help.
Tony
