Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 08-15-2006, 02:30 PM
Derek.C is on a distinguished road
Fanuc O-mc
Is There Anyone Who Knows How To Write A Program To Memory On The Keyboard Of The Fanuc O-mc.
Old 08-15-2006, 04:36 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Can you clarify that just a little more? What it sounds like is that you want to start a new Program or you want to activate specific Keyboard options. Or I'm way off in left field all together.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 08-15-2006, 08:17 PM
Fanuc O-mc
Sorry What I Was Looking To Do Was Write A Small Program On The Control And Save It To Memory. So It Could Be Run In Auto. I Am New To The Control , I Just Purchased It 6 Weeks Ago And It Is A 1989 First Cv-410.
Old 08-15-2006, 10:25 PM
wmyerscnc is on a distinguished road
Select edit mode.
Press letter "O"
type program number (0001-8999)
press Insert.
Good judgement comes from experience. Experience comes from bad judgement...
Old 08-16-2006, 12:04 PM
Tried that all I get is a 086 alarm.
Old 08-16-2006, 12:12 PM
Let me clarify that. The program number registers in the library but I cannot call up the program in auto to run.
Old 08-16-2006, 04:10 PM
I think your machine is set up for DNC, or "tape operation". I'm sorry but I don't have the parameters for a 0-mc control to switch it back to memory operation. I'm sure someone around here would. You might try fanuc or the machine mfgr or distributor.
Old 08-17-2006, 05:54 AM
Thank you. I have a cable coming today and I will hook it up to a computer and see if wiil work.
Old 08-17-2006, 06:56 AM
StephenD is on a distinguished road
try "edit mode"
type program #O0001
press down arrow
Old 08-19-2006, 08:38 PM
Well I hooked the cable to the CNC today , seems like I can recieve to the computer but I cannot send to the control. I am using easy dnc( the one with the port scan) the info I am recieving is just garbage and when I send , I see LSK on the screen flashing and nothing registers in memory. I have the manuals and have changed the parameters , punched the programs in the control and tried to save, all I can do is send my parameters to the comp and they come out as junk. I am confused.
Old 08-19-2006, 09:04 PM
Al_The_Man's Avatar
If your RS232 parameters are correct, make sure your setting data is set to TV check off and ISO/EIA is set to ISO.
  #12   Ban this user!
Old 08-19-2006, 09:18 PM
I have gone through it twice set parameter 0002 to the book 0012 is to the book there must be something else. I have gone through the manuals and looked for everything about sending programs.
