Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 08-08-2006, 04:08 PM
villiersterrace is on a distinguished road
inventor 3d solid to surfcam g code
The engineer draws solid models in inventor and would like to send the files to me to toolpath. I am running a Haas lathe with Surfcam. I dont think I can toolpath the file because there are no lines to chain, just construction lines. Even if I mesh the files I dont see how I can chain for toolpaths. Am I right?
Old 08-22-2006, 08:13 PM
bpmufx is on a distinguished road
Sorry for not seeing this post till now, but what your engineer needs to do is
create a drawing from the solid. From this drawing he can export a DXF file.
this you can bring into SurfCAM to generate your toolpath.
I have done this many many times with no problems. Centerlines can be created in either application.
Evan Brainard
Windmere Design
Autodesk Inventor Consultant
windmeredes@comcast.net
Old 08-23-2006, 06:23 PM
Smile
Yeah, the day after I posted I found you have to buy the inventor translator option from surfcam! I also figured out to change an autocad dwg to dxf but cos I am using Acad 2007 and Surfcam 2005 they arent compatable so I had to save the dxf as a Acad 2004 file. Arent computers great!
