Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 08-08-2006, 04:50 AM
tyrc racing is on a distinguished road
Newbie help, milling machine help needed
Ok, I am apologise for the newbie style questions.
I am afer a milling/drilling machine. I like the look of this one
CLARKE CMD10 MICRO MILL DRILL
Heres the specs
Max Drilling capacity- 10mm
Throat - 140mm
N Load Speed - 100-2000rpm
Spindle Taper- MT2
Motor 150W (230v)
Face Mill Capacity- 20mm
End Mill capacity- 10mm
T Slots - 8mm
Table - 240 x 145mm
Table Cross Travel- 90mm
Table long. travel- 180mm
Weight 32 KG
I want to use this for milling carbon fibrre, aliminium, and nylon. What tool bits, endmills would you reccomend?
Also, what tips to you have as to milling carbon fibre, other than the obvious masks and goggles
Ben
