| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
| There's lots of good choices. Basically most any name brand old CNC lathe with a dead control. For small parts and high accuracy you can't beat the Hardinge CHNC. You can find a decent one with a dead/dying Allan Bradely control for about $1000. On the complete other end of the scale, my Mazak M4 22" x 72" lathe is wonderful also. I almost bought another for spare parts at $1000. But with shipping it would be far more. Its a 10,000 lb. machine. Karl |
| You're in "luck" - there were two recent lathe retrofit threads that just ran recently. One was started by me as "lathe retrofit" several weeks ago and another by FVP just recently (last week) - search of this site with the search engine and both should turn them up readily. Bottom line, converting a manual to full CNC is VERY, VERY difficult task. The old iron/dead control thing gets you the MOST bang for your buck and elimnates a major engineering headache. Good advice - take it!!!! TONS of mill retrofits, yet very few lathe retros that are even the least bit and remotely "simple". If you can NOT do programming, you could be setting yourself up for a nightmare (see "lathe retrofit" thread that i started). If you do anything outside of a Mach s/d stepper motor retrofit, it will get expensive and complicated. Servo based anything tends to get REAL expensive and a bit more complicated because of servo "tuning". Retrofitting a lathe is NOT something I"d recommended for a first time CNC retrofit. |
| Better yet, it was easier to just find the links and post them: Lathe retrofit threads of signifigance: http://www.cnczone.com/forums/showth...lathe+retrofit http://www.cnczone.com/forums/showth...lathe+retrofit http://www.cnczone.com/forums/showth...lathe+retrofit Caveat emptor!!! |
its a pretty good, torquey machine.
__________________ On the other hand, You have different fingers. |
