| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
Exactly how do I get from a CAD drawing (Autocad) to THe point where I can machine the piece. I know I have to transform the drawing into G-code, and then open the G-code with CNC drivers, but: what are some good FREE drivers? When making 3-D parts, do I have to have the drawing in 3-D, or do I do that later What else should I know? Thanks, Alex |
| If you use AutoCAD 2002 and newer, I wrote a macro that will export g code from within AutoCAD. http://www.cnczone.com/forums/showthread.php?t=8226 If not, save the drawing as a v12 .dxf and use ace converter to create g-code. http://www.dakeng.com/ace.html You load the g-code into the control software. The control software actual controls the machine. The only free one I know of runs on Linux, EMC. http://linuxcnc.org/ TurboCNC is $60, www.dakeng.com Mach3 is $159, www.artofcnc.ca For 3D parts, you'd use something like MeshCAM, www.meshcam.com MeshCAM reads .stl files, or .dxf files created with 3D faces only.
