| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
I have a fryer bed mill witha twelve tool turret and an Anilam 6300 controller. I am having issues with the TLO. I have set all my tools off a 2 inch reference. I then go to G53 O1 and use the refprog button and calibrate Z. My tool goes to rapid down in Z but says that it has 17.0 inches to go but is only about 12 inches above the part. When setting the TLO for each tool should I use the re zero my part Z everytime I change tools...I need help!!!!!!!! |
| Before you calabrate z go G53O0 ( this cancels your offset) then in tool F9, (not in offset, this is for your job) put in your tool Ø then hit CAL Z now go back to MDI by pressing F10 now Type your tool No TN M6, will say no tool change but you will have set TLO . You should see that Z changed. This will not have to be done again unless you change your tool. Now still in G53O0 bring tool to the top of job go to tool( F9) then offsets (F1), pick an offset 1-99 then press REFPROG, hit CAL Z turn off REFPROG now exit to MDI (F10) (F10). Type your offset no, G53oN. Z should change to 0, now tool knows where the top of job is. Find datum of job and set x, y, refprog is not required nor is setting G53o0 for X,Y Just remember OFFSETS is for your job (not tool) and has to be set for each job. |
| do any of you all. know some body who uses the anilam 6000M and speaks spanish??? i have a kent JM450 my email is http://rhernand@mlock.com |
| How about you download the manual. heaps of stuff in there that will get you up and running. http://www.anilam.com/anilam.asp?mod=article&actid=27 As for the start and end of a program. START G90 G17 G71 *ABSOLUTE, XY PLANE, METRIC G94 F2000 *FEED IN MM/MIN G53O1 *WORK OFFSET 1 T1M6 *CALL T1 TO SPINDLE S2000 M3 *SPINDLE SPEED, SPINDLE ON M8 *COOLANT ON END OF PROGRAM M9 *COOLANT OFF M5 *SPINDLE OFF G00 Z&P0 *RAPID Z AXIS HOME Y&P0 *RAPID Y AXIS HOME M2 * END PROGRAM hope this helps. |
| Yes I have used conversational programming, this is a fast method to do simple tasks. In post #7. I mentioned the start and end of a program. This should be used and your canned cycles in between the two. this will as you say finish and move the Z axis out of the way. Use the record keys function and type all the code I showed you. Then when you start a new program just use the play function, this way you don't have to write a new start and end each time. program example: 50mm pocket + two holes G90 G17 G71 G94 F2000 G53O1 T1M6 *12 mm slot drill S2000 M3 M8 G00 Z50 G77 X0.000 Y0.000 H2.000 Z-15.000 D50.000 A8.000 B2.000 I1200. P50.000 T2M6 *5 mm drill S1500 M3 M8 G00 Z50 G83 Z-20.000 R2.000 F120. I5.000 P50.000 g00 X-50 Y0 X50 G80 M9 M5 G00 Z&P0 Y&P0 M2 |
#10
| thanks for all your help im using all the examples what you gave me and the machine its runing now i have anther problem the screen is white blank. i was runing a program then suddenly my nextel start ringing and when i answer the screen was white do you think could be interference from the phone??? i can't find a reset botton |
#11
| That's good you are up and running. As for the screen problem I don't know. I would doubt that the problem arose from answering your phone! Reboot the machine and see if this corrects the problem. You may have a loose connection to the screen. |
