Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 04-28-2006, 07:35 PM
*Registered*
Franz Grueter is on a distinguished road
G-Code for bevel cutting head
We have built a cutting machine that can cut a slice of material with a beveled cut. It's a gantry type set up (3 axis) with a 2 axis cutting head. The head can turn 360 degree and the tool can slope down positive or negative down to about 65 degree. The tool always stays centered along the x, y coordinate no mater what the angle is. The tool cuts straight from the top contour to the bottom contour of slice. Any suggestion how best to write G code for this?
Thanks,
Franz
Old 02-17-2009, 08:21 PM
Apples's Avatar
Apples is on a distinguished road
Franz,
What is the outcome? did you workout the g code?
Peter
My little site on MIG welding http://www.learn-how-to-weld.com/mig-welding/
