Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 04-01-2006, 03:09 PM
Al_The_Man's Avatar
Question Delta Tau Anyone
I would be interesting in hearing from any Delta-Tau users/integrators, and how they found the CNC software?
Also how does it compare with other PC based motion card software suppliers?
I saw it at IMTS one year and it looked really impresive. It also appeared that they had a way of integrating Fanuc drives and motors etc.
All input welcome.
Old 04-04-2006, 04:57 PM
Ron22 is on a distinguished road
I work part time as a Delta Tau Integrator.
I have never used their newest version of software PMAC-NC Pro2. I have a copy of it I just have not had time to play with it. I have used and installed their earlier versions 2.36 and 4.0.
As for what do I think of their software well it works and I do install it. It has some bugs and problems but all in all not that bad. I know of a few other Delta Tau integrators that hate the software and refuse to use it.
The Delta Tau PMAC card I believe is one of the best and most versatile PC motion cards out there.
The strength of the PMAC card is also what I believe to be its biggest problem. Because the card can be used with just about any drive/motor combo out there it is also hard to set up and get working correctly.
I have not used a PMAC card with a Fanuc drive so I do not know for a fact it will work.
Old 10-15-2008, 01:15 AM
rohitjain22 is on a distinguished road
Delta Tau PMAC-Lite
Dear Sir,
We have a machine running on Delta Tau PMAC-Lite (ISA).The assy no. is 602402-106.We want to buy a spare card.Do you have such card and what will be the price?
My email address is lastkfc@sancharnet.in
Regards
Rohit Jain
Old 10-15-2008, 02:51 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
I got a Delta Tau PMAC, I use it to make lenses and have only had a few niggles (nothing serious). The card has gone down about twice in 3 years requiring total replacement, but then again, the machine runs a full shift every day, so not bad really.
I love deadlines- I like the whooshing sound they make as they fly by.
Old 10-15-2008, 03:54 AM
spare card
Do you have any idea where i can buy a used card in excellent condition? The assy no. is 602402-106.
Old 10-20-2008, 08:32 AM
ratrace2 is on a distinguished road
Hey ImanCarrot,
What particular model/features of the PMAC are you using?
Care to give a general idea of your system?
Ya know, CAM, CAD, software drives motors etc...that you use in your system?
Thanks Much,
Old 10-20-2008, 10:00 AM
ImanCarrot's Avatar
Hi Race,
I opened the thing up and it says:
"Delta Tau 202-DSPGAT-000
9645TEC"
Also "PMAC V 1.148"
Which reminds me... I got two repair boards out at my supplier... will need to chase them.
I'm using it to control a diamond turning lathe.
Optical encoders control the lathe's position using laser interferometry.
The spindle's an air bearing spindle to reduce friction and expansion caused by heat. The whole lot's liquid cooled to further eliminate heat. And the lab it's in is temperature controlled... hehe I hate heat. Oh and humididty- I got that controlled since the refractive index of air changes with humidity and the lasers think they're somewhere other than where they should be.
Both axes and the spindle float on air and they are on an epoxy granite base. The base itself is floated on active air pads. The lab foundations are over thickness.
Software? I use the normal CAD CAM stuff and some special-to-type applications with custom post processors. I got fed up with limitations on the various lens software packages so I wrote my own. I called it BAGIT (Big Aspheric Generator Including Topography) it does stuff that other packages don't. It's not pretty but it certainly does the job
Old 10-21-2008, 10:10 AM
Hi Race,
9645TEC"
Also "PMAC V 1.148"
Hey Carrot,
Sounds like you have a serious setup. I know what you mean by "hearding cats", I have been going around in circles trying to decide which controller Mfg. I should use. So far, I have pretty much decided on Delta Tau because the other guys are either too flakey or just not--in my opionion--high enough in quality or lack ceratin features like closed loop.
Actually, "the normal Cad Cam stuff is what I'm interested in hearing about in conjuntion with the delta tau controller.
For me, I have been going around in circles with this idea of building a 5 axis gantry router of about 12' x 10' (ft) for about a year and haven't gotten very far.
So I thought it would be a good idea to just build a lab that would integrate all of the CAD CAM Controller software I would need before I actually started buying steel and putting the physical machine together. The steel and gears and stuff is not much of a problem, the software and all of the compatability issues and the notion of writing a Post-Processor, on the other hand; is/has been something of an obstacle.
SO, any thoughts, guidance, ideas you might be able to lend would be appreciated.
Old 10-21-2008, 12:28 PM
Al, I think you might find this interesting. I know personally they work with DeltaTau
www.envoysystemsinc.com
Dick Z
DZASTR
Old 10-21-2008, 01:01 PM
Smile Machine moniters
Dick Z
Interesting, so what would be the practical application of this component?
In other words, I would need this because it does.....?
Regards, Jerry
Old 10-21-2008, 02:08 PM
Al_The_Man's Avatar
Dick Z
Thanks Richard, but since my post over two years ago, I have pretty much settled on galil. They have good support also.
  #12   Ban this user!
Old 10-21-2008, 11:18 PM
I have been working with Delta Tau for a few years now. I have done things from CNC Machines to dedicated stand alone machines.
I haved used Delta Tau older version of thier NC software and there newest verstion of NC software. And custom writen NC software. I have not wrote my own iterface becase I have never had the need to.
Delta Tau NC software is not the best but it does get the job done. Load you standard G&M code program and go. No Cad/Cam option need to be done off line.
