Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 03-29-2006, 06:13 PM
4theast is on a distinguished road
BobCad and EZ Path, EZ Trak
I'm trying to communicate with the contollers on both a Bridgeport EZ Trak controlled mill and an EZ Path controlled turning center. I am using BobCad which works fine with our Fadal mill. I can download programs from both of the machines into BobCad - but I am having no luck uploading programs into them from BobCad. Any help would be appreciated.
Old 03-29-2006, 06:21 PM
*Registered*
lakeside is on a distinguished road
try change you set-up in the cam side to read .cam and upload as a .cam file I've the same issue on the mx3 and I went nuts trying to figure it out also if the controller say line to short you will need to reset software value on set-up page also you need a % at the beging and end
