Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 02-26-2006, 08:35 PM
prochaska is on a distinguished road
Postprocessor for EdgeCAM
Hi all, I'm new here
and I hope I am on right place :-) I can't configure EdgeCAM 10 to generate code for Hurco VMX1 (Basic level of NC code). Does anyone have a postprocessor that is able to create NC code for VMX1 or any advice how to set up EdgeCAM's post processor?
Many thanks for any help!
Ales
P.S. forgive me for my english :-)
Old 02-27-2006, 05:05 PM
wisp's Avatar
wisp is on a distinguished road
send me some example g-code for your machine that includes drilling,tapping, etc... and i will see if any of my posts are a close match.
www.cncfusion.com CNC kits for Sieg mills and lathes
Old 03-01-2006, 07:22 AM
azores is on a distinguished road
Use you code wizard, you can find some examples that come with it.
It's not that bad to change values, if you have a dealer that you bought the software from he should hook you up.
Good luck.
Old 03-01-2006, 10:55 AM
Thank you for replies. I have no example of working g-code still, because I have CNC machine for few days only. But I probably found mistake, it was in using compensations - I didn't know that machine compensation (G41) doesn't need to use. I use compensation by pathtrace and now I can meanwhile work until I obtain regular postprocessor from EdgeCAM dealer.
Old 03-01-2006, 08:10 PM
Smile
No problem, you will find that using centre line with comp a great feature, it allows you to go into rads that are smaller the rad with out going into alarm.
Old 03-09-2006, 09:33 AM
stefanbaarstroe is on a distinguished road
Hello..
goodbye
Old 11-17-2006, 07:02 AM
smoregrava's Avatar
smoregrava is on a distinguished road
This may help?
I found two post for Hurrco maybe they are close to what you need.
The first is for Hurrco ultimax 3
The Hurrco is forHurco VM1,VCM40 & VCM50. don't know anything about these post so you try them at you own responsibility
Old 11-22-2006, 05:31 AM
Thank you, it is what I needed.
