| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
| Lamentations of a newbie... Am I alone with the following issues? When I assert that I'm a newbie, you have to understand that metalworking is totally new for me - been a woodworker all my life but bought a couple of mills and lathe over the past several months. The problem is with software and trying to teach myself to use my CNC Taig mill. Demos are restrictive enough to hamper my learning process with their 30 day expirations and limited features and inability to save to the formats that I need to test. I wound up buying Mach 3 to eliminate the 1000 line limit - probably the only purchase I won't regret. I also bought Rhino because of the 25 save limit staring me in the face and because I had to pick something that would save to enough formats to be able to test the different CAM apps that I'm demoing. Sheetcam only allows 150 lines... Other CAM apps are about to expire and my full version of Rhino won't be here until Monday. I feel like I'm trying to teach myself something that just isn't very easy to pick up at home. I don't know of any other way for the software manufacturers to do it though - they have to put limits on their demos, but when you're in my situation, that pretty much screws you... Anybody else find that they're trying to teach themselves CAD/CAM against the clock... And failing? Mark |
| I did the same thing 4 years ago and hated having to make a decision based on more guess than fact; but I bought Mach and Rhino also and I haven't found anything yet I can't do. Taking one class at a community college doesn't hurt either. With the tuition, you can now buy at a student discount. Sometimes this is less than 20% of the retail price. Very few limit the functions on student copies. Oh, and the education hasn't hurt me none neither anyhow. |
| One thing I notice is that a lot of people ask very general questions that are nearly impossible to answer, like "What software should I buy?". But once they buy it, they rarely ask questions on how use it. There are plenty of Rhino users here, and plenty of SheetCAM users as well. Ask very specific questions, in the appropriate forums, and you should get all the help you need. As for Rhino, there are tons of tutorials on the web. Nothing will help you faster than working through tutorials, imo. If you plan on using SheetCAM, I doubt you'd hit Mach 3's 1000 line limit unless you're doing pretty complicated stuff. I've played with the demo, but don't use it. But once you get the hang of it (do the tutorials ), it's pretty easy to learn. Everyone who uses it swears by it.If you plan on doing 3D work (I thought I remember you saying that), then SheetCAM won't help you. Take a look at MeshCAM for that.
| Also, start out slow. Draw a few lines in Rhino, run them throiugh SheetCAM to see what's going on. Then do a little more, a little more, and so on. Work your way up, don't try to do a complex project all at once.
| There is a lot to learn, no argument there. Perhaps it would have been better if you had picked up a textbook on the subject, to familiarize yourself with the general concepts before you went shopping for the software. I would sit down and write some simple programs by hand first, just to see the machine move, according to my input. Once you thoroughly understand how to write gcode, then you are ready for studying the output from a CAM and not feel totally vulnerable as a slave to your own computer. Even OneCNC, while it is fairly simple to learn for those who are knowledgeable about the subject already, does not teach you how to read and write gcode. Whenever I read the requests of those begging for a preconfigured post suitable for a particular machine, I feel sorry that they are not seeking to understand the principles that underlie making a post work properly. If you practise writing some gcode, and work from simple to complex via a series of your own projects, you will learn every detail required to make the machine work exactly correct. Then, CAM is quite simple to master. At that stage, then you go shopping for CAM that will dependably simulate the program for you, so you don't have to wade through every line of gcode, instead, you will get a general overview of the results. You will want the software to give you a rendered model of what it cut, so you can examine it for blunders in setting up the process. You will want CAM that makes it easy to make a new process, should you decide that you don't like how the first go round went. I often do this: create a program with my best guess about how it should be done, go out to the machine and run it, then I take notes about what I need to fix, about what doesn't work so good in the sequence I originally planned, and then go back and do a major revision. Using good, well-thought out CAM like OneCNC makes this whole scenario execute very quickly. If the CAM you are using does not make this handy to do, then its the wrong CAM for you.
| Im not sure if they still do it or not but SheetCam used to offer a full funtional license for 30 days, If you email them they would send it out. Im not sure if you have aready did that or not. |
The crazy thing about Rhino is that like most software apps, it helps to save as you go so that you can backtrack, but Rhino gives me that "hey, dumb-dumb, are you sure you wanna waste a save now?" message every time That's why I figured that unless I have a version that I can use without fear of actually using it, I won't learn much. Once the licensed version arrives and is installed, I'll really start to bug the Rhino group! I know that I said that 3D was my focus, but, as I keep learning, I am realizing that 2 1/2D may work for some things too. Sheetcam didn't seem like an option until just recently and I've been doing the demos in it too, but my objects have a lot of curves and the line limit may be a problem - I'll know this week for certain. But I did hit Mach 3's limit with my 3D stuff pretty quickly. It seems that 1500 lines is my average and these aren't complicated objects either... Hmmm... But you'll see me around these parts a lot in the future - there's soooo much to learn... |
What's crazy is that I went to the local bookstores and they carry NOTHING at all on the subject and their special order people couldn't help me either. And this was Borders and Barnes and Noble! I'm seeing the benefit of learning gcode - just need to research that too - just another thing to research/study/learn... It was mentioned that I should take a class - that's a pretty good idea! |
#10
| Here is a list. Once you find the titles you want, maybe you can find them cheaper elsewhere. http://www.industrialpress.com/en/topics.asp?topic=MS
#11
Wow... Thanks - that's a lot to choose from! I just with the local stores had some so that I could look at them and see which ones I liked. Some of these books are expensive and if they are a bad read, I'll be out of luck. Reminds me of my network admin days - buying a book without getting to look through it was risky! |
#12
Nobody seems to use them anymore, but, there's always the public library. A lot of colleges & universities will allow anyone to use their libraries, also. Most require you to be a student or instructor to borrow books, though. Still, a few hours here and there at the local community college should allow you to start filling in those knowledge gaps. Best of all it's free or nearly free!HayTay |
