Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 02-07-2006, 04:07 PM
*Registered User*
Bluesman is on a distinguished road
One More Macro ? 16I
Will this work IF[[#3022GT70000.0][LT150000.0]]GOTO10
If not any ideas on how to do this function without spliting into a 1/2 dozen statements
Bluesman
Old 02-07-2006, 05:30 PM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
Bluesman
I think this is what you want:
IF[[#3022GT70000.0]AND[#3022LT150000.0]]GOTO10
Regards,
Scott
Old 02-07-2006, 05:41 PM
Dan Fritz is on a distinguished road
Macro statement
Bluesman: You need some kind of boolean operator in the middle of this statement to make it work. Your original statement is:
It sounds to me like you're trying to find out if the value of #3022 is between 70000.0 and 150000.0 and, if it is, jump to line N10 of your program. Any value less than or equal to 70000.0 or any value greater than or equal to 150000.0 will fail the test, and the program will procede to the next block.
Now, if we break this down, you can see that the part [#3022GT70000.0] is either going to be "True" or "False". You then need to put an AND operator after it, then make another True/False expression, like [#3022LT150000.0]
Here's what I mean:
This statement tests the first True/False expression: [#3022GT70000.0]. If that expression is True, then it tests the next expression: [#3022LT150000.0]. If that is ALSO true, then the entire expression after the IF statement is true, and the GOTO statement will do its thing.
Hope this helps.
Old 02-07-2006, 05:47 PM
MetLHead's Avatar
Gold Member
Yes, what Dan said!
Old 02-07-2006, 06:06 PM
*Registered User*
Here's what I mean:
Hope this helps.
That is precisly what I need, I am not sure why I did not know that, I have been doi9ng this for so long . Sometime you just need a bit of a boost. Thanks Scott
Bluesman
