Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 10-25-2005, 12:26 PM
WilliamD is on a distinguished road
Noob software question...
I have autocad 2000, and am able to draw my woodworking stuff in 2D and my 3D needs. I have mach3 to run the controller and CNC. Do I need anything else? Should I be able to just export the DXF file from Autocad to mach3 and it translates it? Is there anything I'm missing? I'm sure I can do that, but is there a better way? Thanks for any advice!
Old 10-25-2005, 02:12 PM
drawbar's Avatar
drawbar is on a distinguished road
Take a look at www.deskam.com. I have had good success with this program. You can open up dxf's and generate good roughing and finishing passes. Plus the CAM output is customizable. It has a free trial period.
Brian
Old 10-25-2005, 06:16 PM
ger21's Avatar
Mach3 can read 2D .dxf's, but is limited in what you can do. It may be perfectly fine for your needs. A great low cost option would be Sheetcam. www.sheetcam.com If you want to do 3D carving, check out MeshCAM. www.meshcam.com
I don't think it will work in ACAD 2000, but I wrote a macro that exports g-code from within AutoCAD and does a lot more than Mach3 will. It works in 2002 and newer, but it may work in 2000. You can try it and see. http://home.comcast.net/~cncwoodwork.../AC2GCv039.zip
