Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 09-19-2005, 02:44 PM
moorport is on a distinguished road
Hurco BMC20 Post Prosser help
Hi, I have been running haas machines for 3 years and moved into a larger shop with an 91 hurco bmc20. I am having trouble posting code from my CAM software that will work on the hurco. My problem is begining and ending lines and arcs. I have stack of manuals, but nothing is working. Does anyone have a post prosessor file for UPG that will work with the Hurco?
Old 04-18-2006, 03:25 AM
smellyfeet is on a distinguished road
Did you have any luck finding one? I need the same thing but I am having a hard time location one.
Thanks.
Old 04-18-2006, 10:01 AM
Nope, no luck here.
Old 04-18-2006, 09:18 PM
Castle1 is on a distinguished road
Hurco Post
Moorport, I had a similar problem with a 'Max 32' Hurco similar to 'Ultimax 3'. I had the post Processor set to output incremental arc centers instead of absolute arc centers. Our Hurco has to have absolute arc centers, the post has to start with "%" and end with "E". Not sure this will help - ours is a little older 1986, that was upgraded in '97 to Max 32.
Old 04-19-2006, 12:59 AM
Thanks, I figured that one out soon after my original post, but I still cant figure out drilling canned cycles so I use my haas when I need to drill holes, or go back through and manualy edit the program.
Old 08-29-2006, 08:58 AM
Steve A. is on a distinguished road
Can you tell me how to manually write the programs and edit in Hurco BMC-20?
Steve
Old 11-15-2006, 02:47 PM
chipman is on a distinguished road
dynapath delta 20
I hope someone answers you I need the same info.
Todd
Old 11-25-2006, 09:27 AM
javed08 is on a distinguished road
post processor for Hurco--- solution
hi,
For Hurco BMC30 (ultimax II ) you need to output absolute arc center (i,j control dosen't recocnize 'R' ) and just add G75 in start block and end programme with 'E'
Javed
Old 12-02-2006, 04:52 PM
forrey45 is on a distinguished road
I run a VMX30 and it was a shock to me also, with the hurco bmc code the drilling cycle has all positive Z's and no R plane but you can have an extra Z ahead of the peck Z that acts as a first peck and return point? very strange.I got my boss to get the ISNC softwear for the machine that will make it act just like a fanuc control so I can post right from mcam.
Forrey
Old 02-03-2007, 05:49 PM
78 stingray is on a distinguished road
hurco post for gibbs?
So does anyone know if there is a Hurco max 32 post for gibbs?
  #11   Ban this user!
Old 02-04-2007, 03:44 AM
judleroy's Avatar
judleroy is on a distinguished road
I've been running a BMC 30 for about 4 years. It has a
ultimax3 control. If your machine has conversational control I would use that for drilling and tapping. Just tell
the control where the holes are how deep to drill and what the peck depth is. Also tell it the tool info. With the
hurco I only use G-code for 3d contouring. If you have
the conversational and set it up right I find it lowers
cycle times quite a bit.
  #12   Ban this user!
Old 02-05-2007, 09:34 PM
FRANKFMON is on a distinguished road
I Have two Kitamura Mycenter one with Fanuc 6 controllers and 3M displays with Master cam 9 MPFAN or MPBASIC it
puts out a G54 And the a axes It workes if I edit it out,
and put in a safty line (G90 xxxxxx G28 0 befor the the tool
change...
Dose anyone have a post pr. that work's on these older
Mills?? Or do you Knon of someone that, could write one
or modafie MPBASIC Frank M.
