Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 08-23-2005, 08:03 PM
nybuxt is on a distinguished road
Dynapath System 10 Monitor Failure
I have Dynapath system 10 contols on a mill that was just moved by a rigger. When the machine was moved anything that was sitting on top of the control cabinet got tossed inside of it without my knowledge. When I powered up the machine the moniter failed to power up and I found an allen wrench sitting on the PC board for the monitor. It had blown a resistor on the board, but I do not have any manuals for the machine and cannot determine the value of the resistor by it's color code. There may be more wrong than just a blown resistor but I can still read part numbers on everything else should they need replacement.
If anyone should have a schematic or have a machine with the same controls and can give me the color code i would greatly appreciate it. The resistor number on the CRT PC board is R41. It is located directly under the neck of the CRT on the right front edge of the board when looking at the back of the CRT.
Any help would be greatly appreciated.
Old 03-01-2008, 02:07 AM
machinist360's Avatar
machinist360 is on a distinguished road
Are you still looking for this info?
"Fire is cool" -Beavis
