Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 05-25-2005, 08:59 PM
BobL is on a distinguished road
Internal addressing error
I recently purchased a 1993 ExplorerI with a DX32 V2.30/4.54 operating system. I also purchased a OneCNC XR Advantage cad/cam to convert my Solid works drawings to machine code.
I can copy a .txt post from the A drive to the C drive but when I try to move it to the BMDC to run the program I get either a "Parser #4 internal addressing error "or the same thing only #10.
Can anyone tell me what these error codes mean?
Would setting up a DNC help? Or does someone know of a change I need to make to the post?
Please bare with me I'm new to both the Cam & machining world.
Old 05-26-2005, 11:55 AM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Bob,
You might want to post this to the Bridgeport section, as it most likely has to do with the control..And there are some smart BP guys that follow that section. And they might not see it here.
If they can tell you what that error relates too then we could help you set your post up to match..if need be.
Internal Addressing Error BobL Bridgeport and Hardinge Mills 11 06-06-2005 05:11 PM
Internal Gears??? itsme General Metalwork Discussion 11 02-11-2005 02:21 PM
Fadal error codes HareBall Fadal 3 01-22-2005 07:52 AM
Need help on Hitachi Seiki error 1012 anti-SAMS Machine Problems, Solutions , Wireless DNC, serial port 1 11-24-2004 07:26 PM
Compensating for ball screw lead error? Noah General Metal Working Machines 2 08-12-2004 08:51 PM
