Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > General CNC (Mill and Lathe) Control Software (NC)
General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here!
Old 05-15-2005, 06:53 PM
mikejkd is on a distinguished road
5 axis software
I want to take a drawing from Rhino and get tool path for a five axis machine I am building. Does anyone know what I will need(stepper, servos, drivers, etc). I was looking at Camsoft but do not know what drivers are needed.
Old 05-15-2005, 11:46 PM
Splint is on a distinguished road
What exactly are you asking? Do you need to know what software generates 5 axis code or do you need information about the requirements for a machine?
Old 05-16-2005, 06:56 AM
I need to get a program that will generate 5 axis code and make sure that it will be compatable with whatever driver I decide to use.
Old 05-16-2005, 08:45 AM
ger21's Avatar
The cheapest would probably be Visual Mill at $5000, but it only does 5 axis indexing I believe. You probably have to spend $10K or more.
There is the CNC Toolkit, which is free. http://www.rainnea.com/cnc_toolkit.htm
Old 05-16-2005, 12:06 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
VM's not up to 5K yet is it?
I got mine for 1500 (VM4 promo then upgrade to 5)
But ger is right 5th axis in VM is index only - not continous.
www.integratedmechanical.ca
Old 05-16-2005, 01:05 PM
ger21's Avatar
My mistake. $4000
Old 05-16-2005, 01:40 PM
I must be missing something, isn't Camsoft $2000 and generate code?
Old 05-16-2005, 02:00 PM
ger21's Avatar
I believe Camsoft will just run your machine, it won't generate any code.
They do sell this, though. 5 axis code for $18,000.00 http://www.camsoftcorp.com/prod01f.asp
Old 05-17-2005, 06:02 AM
Surfcam and Mastercam both have dynamic 5 axis capability, not sure of the price but I suspect $15000 to $20000.
Onecnc has 3+2 (meaning 4th and fifth axies are positional only). Search Google for 5 axis cnc software, that should bring up a few more names.
Old 05-17-2005, 08:00 AM
Rekd's Avatar
Rekd is on a distinguished road
I believe the "lesser" versions of Mastercam have 3+2 as well, but you get all the other bene's of the top CAM system at a more affordable price.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
  #11   Ban this user!
Old 10-30-2007, 06:32 AM
yohudi is on a distinguished road
CNC_Toolkit...
CNC_Toolkit IS free for personal use and testing.. and it's very powerful if you understand how it works and the way to use it..
Part 1 and 2 of a brand new detailed user guide for CNC_Toolkit are out TODAY.. available as a free download from the yahoo group in my sig.. I made the guide..
Rab Gordon, the creator of CNC_Toolkit has contributed suggestions and has approved the distribution. Part 3 covering the deployment and use of multi-axis rotary configurations is currently being developed and tested...
If you have any interest in CNC_Toolkit then it's worth a read, feel free to pick up copy...
ttfn
Danny (aka Yohudi)
What one man can do another man can do..
BitMaps to Models, 3D2Relief, tutorials and FREE CNC Software http://cnc4free.org
4 Axis EDM software , used to create foam cutting path? bgriggs Foam Cutting Software 1 09-29-2005 04:52 AM
cam software for 3 axis machining mtechserv General CNC (Mill and Lathe) Control Software (NC) 3 05-18-2005 03:35 PM
What Cam software for a 9 axis machine? nervis1 General CAM Discussion 13 11-26-2004 10:25 PM
software for 4 axis zylotex/sherline setup shindin Xylotex 2 10-15-2004 04:58 PM
5 axis software slpd General CAM Discussion 3 08-02-2003 08:57 PM
