| General CNC (Mill and Lathe) Control Software (NC) General Discussion of CNC (Mill and Lathe) control software here! |
| Hi all, Just had an Okuma LT300 for a month now, having alot of problems getting the P coding right to syncronise the twin turrets etc. Does anybody have some experience with this type of machine on this forum? ANY help would be appreciated. many thanks, Simon B. London, Ont. Canada. |
HI HERE IS THE TWIN TURRET PROGRAMME.DONOT RUN THIS PROGRAMME.JUST EXAMPLE ONLY TRY TO EDIT YOUR PROGRAMME AS LIKE THIS P NUMBERS.I PUT SOME EXPLANATION IN BRACKETS . ANYTHING ABOUT OKUMA LATHE PLS SEND MAIL TO ME I WILL SOLVE THE PROGRAMME AND SEND IT BACK TO YOU.MY MAIL ID IS COVAIGOKU@HOTMAIL.COM. GOOD LUCK N0001G13 (PROGRAM USING TWO TURRETS) CLEAR DEF WORK PS LC,[-15,0],[15,13] PS LC,[0,0],[07,81] PS LC,[07,0],[20,25] PS LC,[27,0],[06,46] PS LC,[33,0],[10,13] END (DO NOT RUN THIS PROGRAMME IT IS AN EXAMPLE ONLY) DRAW N20G14 N30G0X30.Z20. N40G50S1800M59 N50G111 N60G13 N70G0X24.Z12. N80G50S1800M59 N90G13 N100T0404P180( P MUST BE SAME IN 'B' TURRET) N110M08P190 (P MUST BE SAME IN 'B' TURRET) N120M42P200 (P AND RPM RANGE MUST BE SAME IN 'B' TURRET) N130G97S450M03P210 (P AND RPM MUST BE SAME IN 'B' TURRET) N140G0X0.Z5. N150Z4.177 N160G95 N170G1Z3.577F.004 N180G0Z4.177 N190M09P220 (P MUST BE SAME IN 'B' TURRET) N200G97S600M03P230 (P AND RPM MUST BE SAME IN 'B' TURRET) N210X24.Z20 N220G14 N230T0424P180 (P MUST BE SAME AS 'A' TURRET) N240M08P190 (P MUST BE SAME AS'A' TURRET) N250M42P200 (P AND RPM RANGE MUST BE SAME AS 'A' TURRET) N260G97S450M03P210 (P AND RPM MUST BE SAME AS 'A' TURRET) N270G0X0.Z5. N280Z4.177 N290G95 N300G1Z3.577F.004 N310G0Z4.177 N320M09P220 (P MUST BE SAME AS 'A' TURRET) N330G97S600M03P230 (P AND RPM MUST BE SAME AS 'A' TURRET) N340X24.Z20. N350M02 |
| I know Okuma's well. Have 8 I program daily. If you have a program that is causing issues, you can email it to me at jscott@airtomic.com and I will help you get through the P issues. Be best to just see an issue on your end, and explain what you are doing wrong -vs- trying to explain all the tricks to using them Jeff |
| Sherline spindle to 30k RPM -- am I crazy? | nicad | General Metal Working Machines | 21 | 11-17-2010 02:57 PM |
| CNC Controlled Spindle motor speed control | gregmary | General Electronics Discussion | 13 | 02-27-2009 07:01 PM |
| Mill spindle repair? | kong | General Metal Working Machines | 6 | 04-02-2005 12:01 PM |
| Gilman box spindle pics | Swede | Benchtop Machines | 5 | 03-30-2005 09:41 AM |
| 2.2KW Allen Brad. Spindle motor? | GalaticDan | Servo Motors and Drives | 2 | 02-02-2005 11:46 AM |
