Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 02-04-2010, 08:57 AM
3030_TRUMPF is on a distinguished road
TRUMPF SOFT PIECING PARAMETERS
Does anybody have some piecing parameters for a soft pierce on a 4000kw
Trumpf laser? I am cutting 1/2 inch mild steel
Old 02-04-2010, 11:05 AM
Independent CNC is on a distinguished road
Post
You should have the tech tables in your machine and make sure that you are using a 7.50 FOCAL LENS. For a Trumpf 2030 to soft pierce this is how the line of code would read TC_LASER_ON(1, “ST050OC17”, 11, 100). This is for a Siemens control and may not apply to your laser.
To explain this line (Laser method, “Laser Technology table”, Piercing type, Cutting type).
What year of machine do you have?
Independent CNC Programmer
http://www.independentcnc.com
My mission is to share CNC programming innovations for a lifetime.
Old 02-04-2010, 11:55 AM
Thanks for the reply
I am actually looking for the parameters in menu 1152 it is where you set the percent of power and ms for the soft pierce.
The machine that is giving grief is a 1999 2530 it does not have PCS.
Old 02-04-2010, 12:28 PM
Post Sample Trumpf 3030
Sorry I cannot help you with that controller. I would call Trumpf.
Do you have a Trumpf 3030 with a Siemens controller? I am looking for a sample program for this machine.
http://www.independentcnc.com/
Old 02-04-2010, 02:14 PM
We have 2 3030's although we use lantec post to program. I think it should work though, the files are .lst I don't know what you want?
Old 02-04-2010, 02:40 PM
Yes if I can get a LST file. Send it to gking@ctcn.net.
Thanks!
Old 02-04-2010, 02:49 PM
What kind of file
anything
test cut for buying a machine
5X10 sheet nested
part thickness?
Old 02-04-2010, 03:00 PM
Post
I am writing a post for the software I use and 16 gauge 4 x 8 sheet material will be fine with just some simple parts. The code at the header of the .lst file is what I am interested in.
Trumpf Vectormark DIFF OVER Laser Engraving & Cutting Machines 1 09-09-2010 06:17 AM
piecing together the remainder??? millman52 General Electronics Discussion 2 11-02-2008 05:20 PM
You own a Trumpf L3050??? tikrik Laser Engraving & Cutting Machines 9 10-20-2008 02:05 PM
Metalsoft/trumpf Heftifab General Metal Working Machines 7 06-07-2008 08:07 PM
trumpf bosch cjerickson Post Processor Files 0 07-29-2005 07:54 AM
