Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 01-27-2010, 11:17 AM
Ranger79 is on a distinguished road
Would like CAM Software Suggestions
Hi All!!
I'm new to the forum. CNC routering has been a hobby of mine for a number of years now. I have always used Illustrator as my CAD program, and Rams 3D to toolpath the drawings.
I currently have Rams 3d and I am considering updating to Rams Pro. But I would like investigate other programs before I decide. I do not need a CAD/CAM program, but one that focuses on making toolpaths.
I could use the options of machining unmachined areas, as well as scaling the drawing offered in Rams Pro. I would also need it to accept line drawings in EPS format from Illustrator. But one option that I would very much like, is to be able to import drawings with color lines into the CAM program.
Is there a program out there with the simplicity of Rams3d, but with this option?
Any suggestions would be helpful. I'm excited to be a part of CNCzone.
Jon
Old 01-27-2010, 01:25 PM
CNCRim's Avatar
Hadn't worked with Ram, and there are so many CAD/CAM out there to choose from it's hard to said this is for you ...... blah blah, but I would recommend FeartureCAM it's great and you can download and play around with it for 30 days. I, personally like Surfcam because that's what I start out with and I can get thing around so it's for me but for some don't like it ....... Try featureCAM.
Old 01-27-2010, 02:11 PM
Thanks for the suggestions. Can FeatureCAM or SurfCam import EPS format?
Old 01-27-2010, 04:42 PM
ger21's Avatar
Vectric's programs can import EPS. Not sure about colored lines, but you can use different layers, each with their own colors.
Tags
eps, illustrator, rams pro, rams3d, toolpaths
CAD CAM Software suggestions jimmy996 General CNC (Mill and Lathe) Control Software (NC) 7 06-30-2010 09:01 AM
software suggestions for art patterns TammyVB CNC Plasma and Waterjet Machines 7 08-20-2009 02:57 AM
Looking for new CAD/CAM software, suggestions....? automan9482 General CNC (Mill and Lathe) Control Software (NC) 4 01-08-2008 06:48 AM
Suggestions for CNC software AccuDave Open Source CNC Machine Designs 1 04-13-2006 09:47 PM
control software suggestions? daedalus General CNC (Mill and Lathe) Control Software (NC) 9 09-25-2005 02:29 PM
