Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 12-10-2009, 04:03 AM
jrobson is on a distinguished road
Cam software with 3-Axis undercut support
Hi
On this document, Page 8 it describes how an undercut is performed: http://www.mastercam.com/CamZone/New...2003-final.pdf
What other CAM software supports undercut operations in 3-Axis mode? Or put it this way, what is the cheapest CAM package that supports this function?
Regards,
Jonathan.
Old 12-10-2009, 04:27 AM
Want to add, it is for 3d with a imported surface, will use a lollipop cutter, can rough with Surfcam, but Surfcam doesn't support undercutting in 3-axis mode, so need a cheap package to just do a Z-Level finish.
Old 12-10-2009, 05:33 PM
moldcore is on a distinguished road
I’ve done it with Surfcam using a lollypop cutter and radius keyway cutters. Just pick an individual surface, one at a time, and set the gouge check to none and watch your feed in and feed out settings. It’s not as automated like the new Mastercam you reference to above but it will work on single surfaces. As far as I know, multiple surface operations will look for gouge avoidance and won’t go undercut with no way of turning it off.
Old 12-11-2009, 03:05 AM
I'm using a single surface, it's a curved port/hole, I've tried for hours, and have been told it won't work. Sadly though MC has had this "feature" since 2003, Surfcam should just give you the option to use the shank instead of the tool for gouge avoidance, it would solve the problem.
Old 12-11-2009, 12:12 PM
CNCRim's Avatar
Sometime long hand program is need it, even with expensive software. I guess you have to mipulate the geometry.
Old 12-11-2009, 03:32 PM
BurrMan is on a distinguished road
Could you fake it with 2d operations? I dont know mastercam so cant really direct you.
Can you post the surface in question here?
If your just doing a z level finish with soem kind of step, you could project some geometry onto the surface at your stepover, then just run profiles on that geometry?
Just thinking out loud.
Old 12-11-2009, 07:17 PM
So I guess it would look something like this:
Create as many as you wanted for your stepover resolution. You would just have to manually know that the tool selected is providing the shank clearance at the bottom profile.
Any thoughts?
Old 12-12-2009, 02:20 PM
Hi, thank you for the help so far!
Yes it is probably possible to do it via 2d countours, but time consuming as well.
Here is the entry
I might be able to get a local guy to help me out with a mastercam generated path instead, but haven't spoken to him for years so...
I have a friend who uses Edgecam, I haven't asked him yet if Edgecam can do it, that could be another possibility, but if one of these cheap 3d art cam packages can also do it then I'd rather get that and finish it with those paths.
Old 12-12-2009, 02:52 PM
OIC,
I was also under the impression that it was an "open surface" like I showed. Much different impression with the pictures posted.
Can you seperate out your inner surface from the model and save it out to an iges or step file to post here? Just save the file to a new name and delete everything except that surface.
Old 12-13-2009, 04:19 AM
See below.
  #11   Ban this user!
Old 12-13-2009, 04:22 AM
Here is something similar attached. My friend says he is sure Edgecam also supports but he'll have a look since he's never tried it on 3-axis, they have 5-axis.
  #12   Ban this user!
Old 12-13-2009, 09:51 AM
Okay, we have the shape, now what size/shape of cutter are you trying to program? How deep are you trying to go into the port? I’m not sure you’ll find a cutter capable of doing this whole port in its present position regardless of the program you use. Even a .500 dia. with a .250 dia. shank won’t do this unless you tilt the hole some or use a 5 axis machine. What version of Surfcam are you using?
Try posting questions about Surfcam in the Surfcam forum. I check the Surfcam forum almost daily but rarely check this forum and I’m sure other Surfcam users only check that forum.
Vision CNC Engraving & CNC Routing Software Widows 7 Support Chart CNC602 Product Announcements & Manufacturer News 0 10-22-2009 07:01 PM
Z Axis support Scra99tch Want To Buy...Need help! 0 03-26-2008 10:46 AM
Machining an undercut in Rhinocam? mike stables Rhino 3D 3 01-22-2008 06:25 AM
4th axis support in BobCad P40Sortie BobCad-Cam 8 09-18-2006 01:58 PM
Undercut Check not perform in g-code Wiseco FeatureCAM CAD/CAM 5 11-22-2005 04:32 PM
