Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 03-28-2005, 07:19 AM
studysession is on a distinguished road
NOOB Questions
Hi -
This past year I took up machining as a hobby and have been learning a lot. I am still confused on softwares. I use Mach2 for CNC'ing on my mill. If I made 3D parts in BOB CAD/CAM and it is supposed to generate the GCode for me from what I understand. Would Mach2 fully understand everything exported from BOB CAD/CAM???
What programs does everyone else use?
I am considering the BOB CAD/CAM 17 Hobby verison:
http://www.bobcad.com/index_hobby.php
I am not sure how well it is compared to other softwares out there. When I do google searched it and Rhino come up the most but from what I can tell Rhino does not export any GCode. I would like to have a program that generated all the tool paths and GCode.
Also for those familiar with Mach2 - Some cuts are pretty deep and Mach2 has a multi-pass function. With using these other programs will I still be able to use the multi-pass function?
Thanks!!!
Please check out my CNC blog
http://cncinside.com
Old 03-28-2005, 07:25 AM
Here are some pictures of items I would like to be able to make myself. I have a 3 axis SIEG X1 Micro Mill.
ID:	6616   Click image for larger version
ID:	6617   Click image for larger version
ID:	6618   Click image for larger version
Old 03-28-2005, 07:27 AM
ger21's Avatar
Yes. You just use a post processor for BobCAM that exports the correct g-code
Mach2's multipass only works for imported .dxf's, I believe. But, your CAM program (BobCAM or whatever) will do the multipass for you.
If you can do your 3D models in AutoCAD, you might just need something like MeshCAM. http://www.grzsoftware.com
Here are some pics of my mill.
ID:	6620   Click image for larger version
ID:	6621   Click image for larger version
ID:	6622   Click image for larger version
Old 03-28-2005, 07:28 AM
THANKS for the quick reply. Have you used MeshCAM before? Or anyone else? Is it any good?
Old 03-28-2005, 07:29 AM
ger21's Avatar
From looking at those parts, I think they can all be done with 2D (2.5D) operations. You just need to make different fixtures for holding the parts.
Old 03-28-2005, 07:30 AM
ger21's Avatar
MeshCAM would NOT be a good choice for those parts.
Old 03-28-2005, 07:58 AM
If MeshCAM is not a good choice - To have something show the tool paths and generate the GCode for me. What would be a good program? I would want something that I can also set the multi-pass with as well.
THANKS
Old 03-28-2005, 08:25 AM
ger21's Avatar
I haven't used BobCAD/CAM, so can't comment on it. And I don't know anything else that will do those types of parts in 3D for less than at least $1000 or more. You might want to look at OneCNC. 3D CAM software isn't cheap. But like I said, I don't think you really need 3D.
Old 03-28-2005, 08:38 AM
kong is on a distinguished road
If all you want is multipass, 2.5d work, take a look at Dolphin at www.dolphin.zenwebhosting.com
Cracking software, and on sale until the end of March (Eeek!). You can download the demo and have a play around, it is fully functional except for the fact that you cannot generate g-code until you buy it! They also have a Mach2 version so you get a Mach2 license thrown in.
Old 03-28-2005, 09:11 AM
ger21's Avatar
Originally Posted by kong
Cracking software
That means good, right?
  #12   Ban this user!
Old 03-28-2005, 10:27 AM
Lol, I just realized what it looks like!
Cracking = very good
Questions - Micro CNC router? DarkWolf DIY-CNC Router Table Machines 36 10-22-2004 09:24 AM
Work has commenced, many questions Tabor DIY-CNC Router Table Machines 3 09-21-2004 11:46 AM
Some Gecko 201 Questions mikie Gecko Drives 3 08-09-2004 11:40 PM
Questions for starting and a formula ... elenabux General Metal Working Machines 3 07-17-2004 06:54 AM
A few honest questions HuFlungDung CamSoft Products 8 06-15-2004 06:24 PM
