| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
#61
Matt, Thanks for the information. Your program is really sweet! Nice work! Could you give me an example of the syntax to send an argument to scomm. Also, how can i tell if the port select is enable or not. I would like for scomm to just send whatever i send it and not prompt to select a port. What lang are you programming in? VB6 or VBnet would be my guess. Thanks again, Brian
__________________ no problem! |
#62
The syntax is very simple, just the program's path/name, a space, then the file to send's path/name. Code: c:\program files\scomm\scomm.exe c:\ncfiles\customer\file.ncf I programmed it in VB6, but am considering a migration to VB.net. (So far my experience with .net has resulted in much longer load times for apps that should load very quickly.) If you're comfortable with computers, you can add SComm to the right mouse menu for explorer, so you can just select a file from there, right click and send it that way.
__________________ Matt San Diego, Ca ___ o o o_ [l_,[_____], l---L - □lllllll□- ( )_) ( )_)--)_) (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
#63
| program called ATD EDIT http://www.atdedit.com/ i use it for my turrent press i use predator DNC for my mills and lathes |
#64
#66
Let me know how it works for you. I'm always intersted in feedback, good or bad.
#68
__________________ Matt San Diego, Ca ___ o o o_ [l_,[_____], l---L - □lllllll□- ( )_) ( )_)--)_) (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Last edited by Rekd; 04-06-2009 at 09:57 AM. |
#69
| Thanks, I have download it and try to install on Win2k, but inatalator always stop on MSVBVM60.dll (7 of 7) and try to install new libraries. Then restart and after starting the instalation again, I recieve the same window and again instalation of new libs and again and again... I tried to take files from cab and put them into separate directory and start it but I recieved some errors and program doens't start. Any suggestions how to make this to run? Thanks Tony |
#70
Hi, I just installed Scomm on XP and had no incidents. The program is nicely laid out. I am interested in incorporating comm into my Autocad abased cam program at the source code level. If that may be possible please sen me a private message. Thanks, Jim
__________________ Jim Short www.tahlinc.com |
| parametric programming | Karl_T | CamSoft Products | 21 | 05-24-2005 02:58 PM |
| How to cut multiple parts (loop a program) | Bird_E | Mach Software (ArtSoft software) | 6 | 05-13-2005 03:16 PM |
| feeds and speeds program | Kees Soeters | General Metalwork Discussion | 3 | 05-12-2005 12:32 PM |
| A few honest questions | HuFlungDung | CamSoft Products | 8 | 06-15-2004 06:24 PM |
| G-Code Cutter Comp Program | jcc3inc | DIY-CNC Router Table Machines | 0 | 02-27-2004 10:29 AM |
