Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 11-11-2009, 04:43 PM
petter@defenceg is on a distinguished road
Question One Lucky Bastard with a 6 axis SEF SR-25
I'm new to this forum but newertheless i would call myself experienced designer.
I use mostly Inventor for modelling but could have used Solidworks just as easily. Uptil now i relied on others for Lasercutters and milling services mostly in China, Norway and Sweden.
I have my own Stratasys FDM modeller for plastic prototyping. but since the Stratasys comes with all the software it need for converting "files to plastic" i have never looked into CAM software.
I stubled upon an incredible deal today a SEF SR-25, with control unit (6 AXIS robot arm)for 1000 EURO, and ofcource i baught it by reflex(havent actually seen it yet but will be picking it up tomorrow).
I have for a long time wanted some kind of robot but has mainly taught about a tradisionam XYZ configuration this i hope is far better starting point than i ever imagined.
I need a starting point on my CAM software exploration.
I manage Linux pretty good.
I can pretty much produce a model of what i get into my head with Inventor but processing the model is something i newer has done myself.
I am hoping for an open source solution for controlling my new toy. But has absolutly no experience with a 6 axis arm, and even less experience with software to control an 6 axis arm.
Where shall i start looking for software to controling this thing?
Do i have to buy something like Mastercam or do i get away with some opensource software?
Is SEF producing any good software themselves?
As i use my own funds i am quite limited in the money spending department.
Every suggestion is appreciated.
Best Regards
The Beginner
Old 11-11-2009, 05:23 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
suppose it depends upon what you want to do , this may be a start http://www.cnc-toolkit.com/ , this is a plugin for gmax , both are free , there is a bit of a steep learning curve but once you get the hang of it then you may find it will suit your needs
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 11-12-2009, 12:42 AM
I have read from googeling that it wont handle my robot arm.
As i see from the cnc-toolkit.com website it's a maximum of 5 axis.
This is a 6 axis. I also think it's based on a xyz table with an additional 2 axis. This is an arm with only rotation axis.
Am i wrong?
I see that RobotMaster can do wery much with this kond of robot.
http://www.robotmaster.com/aboutus.php
Does anyone have any experience with it?
Is tere an Opensource alternative?
Petter
Old 11-16-2009, 11:23 AM
rab's Avatar
rab rab is offline
rab is on a distinguished road
The CNC-Toolkit will handle 6-axes as is and as many extra axes as you need if you're willing to delve into the (open-source) code a bit deeper. The main thing you need to do is model the inverse kinematics of your robot arm using GMAX or 3DS MAX and modify the post-processor to suit.
Rab
(author of the CNC Toolkit)
CNC Toolkit - Open Source 5-axis CAM utilities
www.cnc-toolkit.com : code.google.com/p/cnctoolkit : cnc-toolkit.blogspot.com
Old 11-16-2009, 12:15 PM
Smile
Thank's a lot for the tip, i will try this before i go for my second solution.
I was thinking of hijacking the servocontrollers with a microcontroller to translate xyz a+b into rotation degrees of movement for the arm. This would also prabably also work, but offer little cotrol over collition detection. and add an extra layer of logic.
Thank's again.
Tags
6 axis arm, cam software, inventor, solid works
well i guess its our lucky day preview of the new X4 document ataxy Syil Products 9 09-18-2009 06:16 AM
chopperframe. and me the stupid bastard who deisgns it =) schneberger Solidworks 14 12-10-2008 08:39 PM
Lucky me, Alfred Jaeger spindle owner... zone023 DIY-CNC Router Table Machines 2 04-27-2007 04:02 PM
lucky find...decision time KTP General Metal Working Machines 5 03-31-2006 10:49 PM
A lucky find, a good machine? TimKoene CNC Wood Router Project Log 29 12-04-2005 01:02 PM
