Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 03-22-2005, 01:43 PM
TigerPilot's Avatar
TigerPilot is on a distinguished road
Counter sink hole
I did a drawing in 2d. It has a hole of about 1" diameter. I want to counter sink the hole about a 1/4". I have the tool to do everything except the counter sink, which will be 3d. Can I do it without a 3d program?
Yoram
Old 03-22-2005, 02:15 PM
psychomill is on a distinguished road
Yes. In 2d just interpolate the 1.0" hole with a counter sink or chamfer tool to the size you want. Just calculate for the angle and depth.
Old 03-22-2005, 04:30 PM
TigerPilot's Avatar
I'm using DeltaCad. I may have reached its limits. I cannot chamfer in the top view which is, ultimatly, the tool path view, because it will not chamfer circles. I can chamfer in the side view but that will not help me much if I don't get it into the top view.
Yoram
Old 03-22-2005, 05:53 PM
Can you cut a circle at all? By a contour method? At least that way you'll get some code you can use. Or just hand write it.
Old 03-22-2005, 06:26 PM
TigerPilot's Avatar
Yes, it will cut a circle but don't ask me to modify it since that is what I'm asking you how to do. To me it is still all Chinese.
Old 03-22-2005, 11:07 PM
Since I'm not familiar with DeltaCam (which I thought was only a cad platform... didn't know you can program with it) I'll just try run this over with you assuming some capabilities of the system.
You shouldn't actually have to draw a chamfer to cut it. You already have a 1." hole so use that. Let's say you have a 3/4 x 45deg countersink or chamfer tool. So for purposes of getting code, call that tool a .100 endmill. Now do a contour cut inside the hole. Now you just control your 'Z' depth to get the size you want. Assuming its a 1/4" x 45deg chamfer, you would move in 'Z' (-.250) plus 1/2 the diameter of the tool for a total of (-.300) in 'Z' if you're programming with comp. If you're centerline programming, then you need to add .05 to cutter comp at the machine and still move -.300 in the program.
If the angle of your chamfer is different, say 60deg (30deg) or 82 deg (41deg) then just calculate for 'Z' given those angles.
Hope this is what you're looking for.
Old 03-23-2005, 06:18 AM
TigerPilot's Avatar
Not quite wat I was looking for. :-) First let me say that I did say DeltaCad and not DeltaCam. ;-).
The counter sink was just one exemple of what I want to do it I thing it is the simplest. If I'll solve it I'll know how to do the other one.
In your solution you use a angled tool. What if the tool was flat or ball? How can I do it then?
Yoram
Old 03-23-2005, 07:50 AM
ger21's Avatar
You make multiple passes, calculating the depth and position of the tool at each pass. Not the easiest way, but the cheapest. (no CAM needed.)
Old 03-23-2005, 08:58 AM
Gold Member
Ken_Shea is on a distinguished road
TigerPilot I think we are a little confused on what it is you want to accomplish, at least I am ???
What I think you are needing is to draw the part for creating the g-code later on. If this is the case I do not see a need to draw this counter sink in 2D.
In machining this portion you typically would have three operations.
1) spot drill
2) drill
3) countersink
All using the same center point in the drawing only the tool and depth of cut would change.
Old 03-23-2005, 09:55 AM
ger21's Avatar
He wants to use only one tool, I think.
  #11   Ban this user!
Old 03-23-2005, 11:03 AM
buscht's Avatar
buscht is on a distinguished road
Tigerpilot,
Let's say that you want a 90 countersink. You should draw a bunch of circles, each one .016" larger in radius than the previous one. They should go from 1" dia to 1.50" dia.
In your CAM program, you would have to link each circle to a depth. Each circle would be .016" deeper than the next outer circle. Pocket out each circle.
This will give you a crude 1/4" chamfer around your 1" hole, with .016" steps. If you want it finer, trying using .008" as a step.
  #12   Ban this user!
Old 03-23-2005, 11:04 AM
Well, like this....
Or you'll have to do it in a 3D toolpath.
distorted hole emergent Visual Mill 2 05-09-2005 09:54 AM
Gecko 320 Heat Sink ?s Bird_E Gecko Drives 2 03-13-2005 01:09 AM
Drilling a perpendicular hole in drill rod material ngr1 General Metalwork Discussion 12 12-04-2004 09:16 AM
G-code to zero counter? erase42 G-Code Programing 3 07-18-2004 10:01 PM
Heat sink mounting questions CactusChip Gecko Drives 3 01-31-2004 12:43 AM
