Page 5 of 6 FirstFirst ... 23456 LastLast
Results 49 to 60 of 71
Thread: picture carving
  1. #49
    Oct 2006
    united states
    dertsap,
    Are you still offering a discount for zone members? If yes, then how can we order?
    Rod
    San Francisco
  2. #50
    Jan 2005
    He has it listed here and on sale.
    http://www.cnctoybox.org/store/page71.html
    Milton
  3. #51
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    discount is still available
    you can email me at sales@cnctoybox.org and I'll send you an invoice to pay thru paypal
    just give me your name and what version you'd like
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    http://microcarve.microcarve.biz/
  4. #52
    Oct 2005
    canada
    Milton
    I'm just curious if your making out ok now
  • #53
    Jan 2005
    I think I got it all figured out now, Will tell when I try to route out something.
    I have been playing with the software on my regular computer but the one that runs my router is a older one that still runs on Windows 98.
    Going to load the software on it to see if it works, Will save me a lot of time from having to copy files to take to it.
    Like I said I am simple minded and does not take a lot to blow right past me. LOL
    Milton
  • #54
    Oct 2005
    canada
    one thing that is nice about the software is its portable , you can load it onto a memory stick and run it right from the stick , it makes it easy to be able to work from different computers and do stuff on the fly
  • #55
    Jan 2005
    For some season I can not get software to load on my older computer, The computer does not like the software or the software does not like the computer. LOL
    Will just have to do it when I upgrade the computer for my router.
    But do have one question, If I set up the file to start the cut from the top right corner is that point also zero for XYZ, router bit just touching the board to be cut for Z zero.
    Milton
  • #56
    Oct 2005
    canada
    the toolpath starts at the bottom right corner (xyz)
    are you getting an error message on the pc that its not working on
  • #57
    Jan 2005
    What am I looking at in the pic below, I made the picture smaller than the board is is going to be routed on but the picture keeps coming up at the bottom left corner, How can I center it on the board. ???
    Milton
  • #58
    Jan 2005
    Yes, It is a older computer running in Windows 98, I keep getting the message of What file do I want to open it with and there is no file in windows 98 to open it with.
    Quote Originally Posted by dertsap View Post
  • #59
    Oct 2005
    canada
    to center it to the material then you need to offset it (in the bottom left corner) , xy zero will still be the at the bottom left corner but the code will be shifted to suit ,
    in windows 98 can you direct the software to your documents or to your desktop where you can store the images
    if you have anymore questions then let me know , I'll be around for a good chunk of the day due to the fact I'm once again repairing the brake job from hell , brake hose was rubbing on the tire and finally wore thru , never trust someone else with your vehicle , i got lazy and had someone to do the work and anything that could go wrong has , when the caliper bolts fell out (2nd problem after the slide bolts fell out ) thats when i thought he was trying to kill me , now i know he was
    excuse the rant
  • #60
    Jan 2005
    Finally got to try and cut a file, was cutting the file in the pic above and after a hr of cutting and still less than ½ way through it I stopped.
    It does not cut in one continues motion, If Y is the direction of the cut it will start stop, start stop, Not just move in one continuous motion and Z move up and down as needed.
    It say’s it is cutting 90 inches a min but is a lot slower than that, Is this common or is it the software I am using to run the machine, I am still using Turbocnc running in DOS, I have Kcam on the computer but can’t seem to get it to work.
    Would Mach3 run the G code software better and faster.
    Milton
  • Page 5 of 6 FirstFirst ... 23456 LastLast
    1. CNC for Ice carving!
      By asandoval in forum CNCzone Club House
      Last Post: 03-20-2009, 01:59 PM
    2. Carving cedar
      By grahamshere in forum WoodWorking
      Last Post: 10-19-2008, 02:52 PM
    3. Relief carving small detailed parts - V-carving from greyscale image
      By ALAN2525 in forum General CAM Discussion
      Last Post: 02-11-2007, 06:01 PM
    4. Gcode Carving
      By wcarrothers1 in forum DIY CNC Router Table Machines
      Last Post: 11-11-2006, 11:54 AM
    5. 3D Carving Program ?
      By diarmaid in forum Vectric
      Last Post: 10-29-2006, 04:13 PM
