| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
Hi friends I need your advice. I am an electronics engg graduate. My dad is one of the partners of a growing tyre mould factory in Bangalore, India. I am a software engg by profession and have hardly entered the factory. 1. Can a software programmer like me(c++, flex, java with extensive 3d graphics experience in Maya, Max, melscript and maxscript) get to terms with CNC programming quickly in just 1 week hands on? 2. The programming work at the factory is predominantly with powermill and mastercam. Used to generate tool paths, engravings etc. Will it be easy for a programmer from another domain like me to get to terms. Please note I dont know how lathes and other machines work. I only did a bit of engg drawing in my first year(I am an electronics engg. Can design and code in the Maya/Max 3d graphics environment). My noobness shows in the questions perhaps, but thats exactly what I am ![]() Please let me know what you guys think. Last edited by vij; 10-19-2009 at 04:18 AM. |
| I think the problem is not to learn how programming, because the structures and logics are quiet similar, but to get acknowledgement of the working processes. I mean spindle speeds, Feed rates, tools technology, working CW or CCW around a piece, for example. These are the most important arguments to be a smart CNC programmer. " The problem is not the language, but yours speech !"
__________________ CAD-CAM Manager |
| So I guess, its going to be a steep curve. Slightly deflated... |
| No chance. You'll crash the machines. You'll be able to 'program' the machines, that's easy, but you won't know the machining processes. You need to learn how to cut metal: CAM software makes it quicker, but it doesn't do the work for you. Crashing a computer is a inconvenience - crash a CNC machine, and it can be spectacularly expensive. Find a local tech college and learn about hand-on machining of lathes and mills and you'll be able to start, but it's an endless process. I've been programming CNC for 12 years now, and I'm still learning new techniques for cutting metal. You need to learn the skills. |
| mastercam is quite easy to use. it wont however tell you that your going to snap the end of the cutter of because your doing a ridiculous doc or federate. probably wont tell you that your drilling a hole in the table of your nice machine either.
__________________ ___________________________________________________________________ http://www.cnczone.com/forums/showthread.php?t=86985 my work in progress |
Remember you will need some general machining knowlege. Work with an available Machinist as you write programs... Go Here http://www.haascnc.com/custserv_training.asp#haastrain Look up Lathe and VMC programming manuals. Good Luck. mongo |
#11
vij, I've been a software engineer for over 20 years. C/C++, Java, Assembly, from Windows crap, Unix, micro-controllers - you name it. A couple years ago, I was getting bored - got interested in machining ... still don't know why. It just happens to the best of us. Anyways, got me a mini-mill, mini-lathe and an assortment of tools. Started trying to build what looked to be a simple single-cylinder steam engine model for kicks and giggles. After throwing away the 5th piston that was the wrong size, and getting more than a little annoyed with myself, I realized something: in the software world we are a bit spoiled for 2 reasons: 1) Mistakes are free. If we screw up a C call with some bad pointers and get the infamous BSOD, we just reboot and start over. If we screw up a disk driver, maybe we even corrupt some files or a filesystem - reformat and start over. Time is money, so I guess it is costing you, but you don't do anyone/anything physical damage. No so when you are making something with machine tools: best case, you just made some scrap, next best case, you made some scrap + ruined a bit, worst case: the shop foreman/father-in-law was in the way and your g-code ripped his arm off. (okay, I got carried away) 2) In the software world, the distance between knowledge and skill is very short. When I realized this, I went to online metals and ordered a bunch of whatever they had on sale, then I just practiced nothing in particular on my machines. In the machinist world, the distance between knowledge and skill is much greater. You may know in 1 sec you need to turn a rod down to .501 of a inch, but doing it repeatedly is a matter of practice and patience - kinda reminds me of my dad trying to teach me to play baseball. In the software world, if you understand an API, using it is pretty easy ... knowledge is almost the same thing as skill. CNC will let you shortcut this second point to a degree. I would encourage you however, if you want to help your dad in the family business, to not take the shortcut. Take some time to learn machining manually. If not at a college then at least get a cheap mini-lathe and just make stuff - manually before going CNC. CNC programming (actually 'G-Code' programming) is kinda like macro-languages (kinda like VBA) - you are just automating a machine. Run the spindle too fast on a piece of magnesium and you can start a 4,000 degree (F) fire - that's a fire you can't put out. So bugs in G-code can be really, really expensive ... G-Code programming, compared to "real" software engineering, is easy. Bugs like off-by-one errors on loops won't frustrate you like they do a lot of machinist new to programming. However, knowing what to tell the machine to do is not so easy. A book I found very helpful is called 'Home Shop Machinist' - helped me a lot. Also, don't know if you are into open source or not, but if you are, jump over to www.linuxcnc.org - the home for EMC2 distribution. Get the ISO - if you don't have a real machine & controller, then stick it in a VMWare guest and configure it to run a simulation machine. VMware isn't suitable for running this "for real" because of hardware issues (real-time kernel), however, if you just want to tinker with G-Code, you can play with it and "see" it rendered in a tool called Axis inside vmware just fine. (It uses opengl to draw what the g-code is telling it to make...) Now, this flavor of g-code will be different than the machines in your dad's shop, but it will give you a good idea of how g-code programming works. (g-code is kinda like browser DOMs ... each vendor's is a little different - and just like web development, you want to write you code to adapt to a user's environment.) I like to use python - I use the multi-line strings and interpolate variables to alter hand-tooled g-code. Whatever your favorite string-processing language is can be used to good effect. Or you can just write straight g-code for that matter. I spent less than $1k on my homemade CNC machine including a 4-axis controller (xylotech) - that's a pretty cheap investment for learning a new skill as useful as this. Sorry for the verbose reply. I been where you at... let me know if I can help. |
#12
| Hey Vij, I say go for it, but start out small, so WHEN a mistake does happen, it doesn't rip off your father-in-law's arm like walter.a.gough mentioned, which would be pretty embarrassing and rather unsightly. I'm a programmer too and I built a CNC router from a kit. I just finished it and I've already learned so much and I'm getting a feeling for how much more there is to learn. I started out by simply drawing stuff with a ball point pen under CNC control. So far, my mistakes have only caused a few pens to get jammed into the table and some ripped up paper. Thank goodness I wasn't running the 2.25 horsepower router yet! Anyway, that's my two cents... -Brian |
| Looking for CNC Programmer/Set-up | Melissa Lawson | Employment Opportunity | 3 | 04-10-2008 08:42 AM |
| How does one become a programmer? | ToppDog | General CAM Discussion | 8 | 06-02-2007 12:14 AM |
| Looking for CNC programmer | swa | Employment Opportunity | 3 | 04-08-2007 07:18 PM |
| CNC Programmer | cncjobs | Employment Opportunity | 0 | 02-27-2007 11:44 AM |
| CNC Programmer | bigsmac | Employment Opportunity | 0 | 10-27-2005 05:23 PM |
