Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 10-06-2009, 04:16 PM
jcnewbie is on a distinguished road
New to 4 and 5 axis programming
I'm trying to learn 4 and 5 axis programming on my own. I know I have a lot to learn.
Can someone tell me the difference between 4 and 5 axis programming ?
Thanks for your help in advance.
Old 10-06-2009, 06:17 PM
Superman's Avatar
Superman is on a distinguished road
You can break up the stages of difficulty a little more
and they are placed in order , with the hardest being at the bottom
3 axis - this is the base of most machines
3+1 axis Positioning or Indexing - extra axis added to the base model, you rotate the 4th axis, then bring the tool in to do an operation
Eg 4 holes @ 90 degrees apart on a shaft
3+2 axis Positioning - similar to 3+1 , but another axis added
Eg put the spots on a dice on 5 faces ( you can't do the one underneath )
4 axis Full - Full 3D machining using all 4 axis in the same operation
Eg a helix grroove on a shaft
5 axis Full - full 5 axis controlled movement
Eg surfacing a complex shape, tapers that vary in angle not relative to any plane
Old 10-07-2009, 10:52 AM
thanks for the help !
C-axis programming NewToGibbs General CNC (Mill and Lathe) Control Software (NC) 2 04-07-2009 11:36 AM
Newbie- 4 axis programming slideleft G-Code Programing 0 12-30-2008 01:08 PM
4-axis, 3+2, or 4+ axis programming system? roboticist General CAM Discussion 0 09-04-2006 01:02 PM
4th axis programming smoggy General CNC (Mill and Lathe) Control Software (NC) 2 05-18-2005 11:16 AM
4 and 5 axis programming Cammotion G-Code Programing 1 03-02-2005 11:39 PM
