| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
Hi guys, I have 2 choices for CAD/CAM software to choose from and I really don't know which to go for, the choices are Mastercam X4 or the latest version of Powermill. My application are 5 axis machining and also Robot machining. what would you suggest? |
| Why can you only choose between these two systems??? First of all I think you are comparing an apple to a banana, if you ask me. My system would be Edgecam combined with Spaceclaim because it will do all your 2D, 3D, solid surface and wireframe machining upto 5-ais simultaneous machining remaining fully associative to any CAD system/file you use. This is combined with a unrivalled easy to use userinterface for both Edgecam as well as Spaceclaim. With Spaqceclaim you can edit 3d models dynamicly from anyt file format or cad system. This is handy when you need to adjust models to fit tolerances, or if you need to edit/fix some faces or maybe cap some holes because of machining methods you want to use. best of luck choosen a system Jasper |
"Edgecam combined with Spaceclaim because it will do all your 2D, 3D, solid surface and wireframe machining upto 5-ais simultaneous machining", does this mean Edgecam and Spaceclaim is compatible with Industrial Robot for robot milling?, I have a Kuka KR-150 and I want to do 3d model milling with it, currently my choices are: * Powermill + Camrob * Mastercam + Robotmaster * Edgecam + Spaceclaim Will contact Spcaeclaim for more details, THX |
| Hi Spaceclaim can be used in conjunction to any CAM system, it is a CAD neutral modeling system to edit models or create models from scratch, The power is unbelievable just check their website to download a 30 day full functional free trial. As far as Edgecam is concerned I believe the compatibility with robot machining is a postprocessors issue/challenge. I think you should be able to drive the robotg with any CAM system with a good postprocessor toolkit. The only thing to keep in mind in this is to see how good is the VAR that is supplying you the CAM system, because if the post is not working, the system is worthless. I just looked at the robotmaster website and that looks really impressive! I think what it does it takes a standard mastercam NC output file and converts it to a robot programme and does the simulation etc. Maybe it will also work with other cam systems? I don't know... Hope this helps and good luck finding the right solution. Jasper |
" Maybe it will also work with other cam systems? I don't know..." I asked and the answer is only for Mastercam, unless you use Camrob which accept any cam software. I found another supplier called Robocam, waiting for their answer. |
| I think it's common knowlegde that powermill is among the high-end leaders. Horses for courses and all that. By concidence I was watching some vids on Delcam.tv today; http://www.delcam.tv/ Check out the Garner Holt video of a Kuka robot in action. They're not working to any particular accuracy though (evident just past halfway when the first cut nearly snaps Donkey's head off ).Obviously they're going to show customers spouting greatness about their products, but I can certainly vouch for Delcam's support having been a user and a customer for over 10 years. Where in the UK are you? |
#10
North west London, Harrow-on-the-hill, but currently I'm in Asia. Yes I know Powermill is a great software but too expensive (£22,000 ~ £27,000) for me, and I also heard that there's something that powermill is capable of where Mastercam can not. I'm not sure if it's true, Powermill can run 5 axis simultaneously in less time, compare to Mastercam??? |
#11
#12
| Tell a bit about you, what machine do you have and what software do you use?. |
| Need Help!- nesting mastercam x or mastercam x3 | zewanil | Mastercam | 1 | 05-21-2009 01:30 PM |
| Newbie- m2 -ISO mastercam | gttool | Mazak, Mitsubishi, Mazatrol | 4 | 05-06-2009 02:33 AM |
| Need Help!- MASTERCAM X3 | fenix728 | Mastercam | 4 | 05-04-2009 02:05 AM |
| mastercam help | humbertocnc2007 | Spanish CNCzone | 0 | 02-17-2009 12:03 AM |
| Need Help!- MASTERCAM OR NOT TO MASTERCAM. THAT IS THE QUESTION. | Jonathan E. | Mastercam | 3 | 12-20-2008 11:18 AM |
