Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 09-08-2009, 12:24 PM
Drools's Avatar
Drools is on a distinguished road
getting STL files into Mach3
What is the least expensive way to get STL files into Mach3 for routing. I found a nice free design on cnc4free.org web site but it is in STL format. I have access to AutoCAD 2008 but it does not open STL files without a plugin. Is there another way to get from point A to B without spending a pile of money?
Old 09-08-2009, 01:13 PM
ger21's Avatar
Freemill from Mecsoft is free.
MeshCAM and Cut3D are the least expensive options if you want something better than Freemill.
http://www.mecsoft.com/freemill.shtml
www.Meshcam.com
http://www.vectric.com/WebSite/Vectr.../c3d_index.htm
Old 09-08-2009, 01:53 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
STLWork2 IMSERV (They're on the CNCZone I recall). May still have a demo available. Less than $100 (again as I recall). It has some built in tools - and you can specify your own, will do slabbing, xy or waterline cuts too. You can save as a roughing pass - or finish. It imports you stl file, you specify the shapee of the material you're using, tool etc -- then generate Gcode.
Not a rep - just a satisified customer.
Cheers - Jim
PS -- they frequently bundle some other sw with it so look for accutrans - or rasterfratz with it. Read all about it on their webpage. You google it - bye.
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Mach3 config files Konstantin Mach Software (ArtSoft software) 0 05-15-2009 01:42 PM
Need Help!- Convert files to Inventor files. bartL Autodesk Software (Autocad, Inventor etc) 7 02-03-2009 11:38 PM
Need Help!- Import/Convert DXF or PLT files to Mach3.... Mikael Mach Mill 3 12-25-2008 03:33 AM
Converting Illustrator files to Gcode files acoop101 General Metal Working Machines 1 06-05-2008 03:53 PM
Mach3 converting dxf files problem randyf1965 DIY-CNC Router Table Machines 7 04-18-2006 11:28 PM
