Ok my setup first:
CNC Controller:
Burny 3 CNC Controller (This thing is pretty old also)
Type: MNC3-03462-0
Parts:
I'm making are ALL 2D cut with either the plasma or oxy/acyet from 1/8" to 1 1/4" Mild Steel.
Help:
I just installed SolidCAM and doing all my design out of SolidWorks. I'm just begining to understand how to get things to work correctly with SolidCAM but I still just don't know how I should go about doing a plasma cut (I'm thinking using a slot operation or milling the outside?) I need some help and a little bit of a walkthrough on how I should do these parts.
I need to know what system to use (Like FUNCA or whatever) to make this compatible with my current CAM system.
Also how do I get the SolidCAM software to spit out GCode that can be used by my CNC machine?
SLOT G CODE FOR A DIFFERENT PART I GENERATED:
Code:
O5000 (S_SLOT_T2.TAP)
( MCV-OP ) (18-AUG-2009)
(SUBROUTINES: O2 .. O0)
G90 G17
G80 G49 G40
G54
G91 G28 Z0
G90
M01
N1 M6 T2
(TOOL -2- MILL DIA 0.25 R0. MM )
G90 G00 G40 G54
G43 H2 D32 G0 X2.134 Y4.384 Z3. S1200 M3
M8
(S-SLOT-T2 - SLOT)
X2.134 Y4.384 Z1.4
Z0.079
G1 Z0. F2
G3 X0. Y3.5 R1.25 F4
G1 Y0.
X2.5
Y3.5
G3 X2.134 Y4.384 R1.25
G0 X1.75 Y3.25
G3 X1.75 Y3.25 I-0.5 J0.
G0 Z1.4
M30
Here is a old cnc file that is in current use now for parts (THis file was generated in 1998) just as reference for anybody able to get something out of it.
Code:
Code:
N0P0001
N10G41
N20G70
N30G91
N40X3.7275Y-11.8275
N50G97
N60M4
N70X.0725Y-.025
N80X.1325Y-.035
N90X.12Y-.0575
N100X.1525Y-.095
N110X.095Y-.065
N120Y-.0925
N130G2X-1.525Y.2575I-.7535J.1825
N140X1.535Y-.075I.7655J-.077
N150X-.01Y-.05
N160Y-.1225
N170X-.035Y-.1175
N180M3
N190X-2.94Y2.1875
N200M4
N210X.0975Y-.0575
N220X.11Y-.1325
N230X.08Y-.145
N240X.06Y-.16
N250X.0375Y-.19
N260X.005Y-.14
N270X-.03Y-.0425
N280X-1.19Y.4675I-.434J.6435
N290X-.0275Y.1475
N300X-.0075Y.175
N310X.02Y.1425
N320X.045Y.0925
N330X.19Y.2175
N340X1.2225Y-.365I.488J-.594
N350X.035Y-.1325
N360X.005Y-.1975
N370X-.0075Y-.0925
N380X-.045Y-.1575
N390X-.085Y-.1275
N400X-.0375Y-.03
N410X-.06Y-.0625
N420X-.0875Y-.08
N430M3
N440X.6075Y3.1825
N450M4
N460X.1525Y-.0925
N470X.11Y-.115
N480X.0825Y-.15
N490X.065Y-.2325
N500X-1.37Y.17I-.647J.3915
N510X.3925Y.94I.7345J.245
N520X1.09Y-.545I.3375J-.687
N530X-.1975Y-.68I-.7515J-.1505
N540M3
N550X2.405Y.74
N560M4
N570X.1525Y.0025
N580X.13Y-.0375
N590X.14Y-.07
N600X.1175Y-.0925
N610X.07Y-.0625
N620Y-.11
N630X-.7925Y-.59I-.7495J.1785
N640X-.72Y.7225I.027J.747
N650X.58Y.8025I.757J.0635
N660X.8825Y-.4525I.175J-.745
N670X.0525Y-.1675
N680X.0075Y-.1175
N690X-.0075Y-.09
N700X-.005Y-.1175
N710X-.03Y-.0975
N720M3
N730X-4.3Y2.85
N740M4
N750X.1375Y-.0775
N760X.115Y-.0875
N770X.1275Y-.13
N780X.13Y-.19
N790X.05Y-.1375
N800X-.005Y-.0325
N810X-1.3025Y.1175I-.6175J.4355
N820X-.055Y.1525
N830X.82Y.9625I.728J.21
N840X.68Y-.63I-.092J-.7815
N850X-.2075Y-.68I-.7775J-.135
N860M3
N870X1.9175Y2.4825
N880M4
N890X.22Y-.1475
N900X.13Y-.13
N910X.115Y-.14
N920X.0725Y-.1225
N930X-.03Y-.08
N940X-.94Y-.3125I-.6595J.413
N950X-.4425Y1I.3065J.7335
N960X1.1325Y.3775I.718J-.267
N970X.325Y-.88I-.4205J-.6555
N980X-.035Y-.0775
N990X-.03Y-.085
N1000X-.0425Y-.0675
N1010M3
N1020X-.6325Y3.0225
N1030M4
N1040X-.0075Y-.1775
N1050X.005Y-.14
N1060X.045Y-.2125
N1070X.0675Y-.1825
N1080X.06Y-.1625
N1090X.1075Y-.1525
N1100X2.2625Y-4.93I-5.653J-5.5785
N1110X-1.025Y-4.625I-7.94J-.6665
N1120X-3.09Y-3.0175I-6.8215J3.894
N1130X-1.61Y-.6625I-3.8015J6.95
N1140X-.1Y-.005
N1150X-.02Y.03
N1160X.0125Y.16
N1170X-.005Y2.31
N1180X-.005Y.235
N1190X.005Y3.115
N1200X.0725Y.1825
N1210X.0625Y.1425
N1220G3X.0625Y2.875I-2.2455J1.4865
N1230X-.105Y.175
N1240X-.0675Y.155
N1250X-.0425Y.1725
N1260X-.0025Y.3475
N1270X-.005Y3.15
N1280X-.0025Y.34
N1290X.0025Y1.9225
N1300X.1175Y-.005
N1310G2X1.8175Y-.78I-2.8045J-9.042
N1320X1.5Y-1.1225I-4.232J-7.2185
N1330X.0975Y-.0575
N1340X.05Y-.0825
N1350X.14Y-.155
N1360X.0375Y-.04
N1370M3
N1380X-1.41Y-13.9775
N1390M4
N1400X-.0175Y.0125
N1410Y.02
N1420X-.105Y.0025
N1430X-.13Y.06
N1440X-.14Y.085
N1450X-.1175Y.0825
N1460X-.005Y.04
N1470X1.5225Y-.1525I.756J-.126
N1480X-.7325Y-.7425I-.758J.015
N1490X-.7925Y.66I-.0345J.7645
N1500X.0025Y.1
N1510X.0075Y.085
N1520X.01Y.1325
N1530X.025Y.0775
N1540M3
N1550X2.6825Y-1.905
N1560M4
N1570X-.065Y.1325
N1580X-.0475Y.1575
N1590X-.02Y.155
N1600X.0025Y.095
N1610X.085Y.08
N1620X1.1775Y-.6175I.401J-.6665
N1630X-.005Y-.19
N1640X-.04Y-.14
N1650X-.065Y-.1325
N1660X-.0825Y-.1225
N1670X-.02Y-.04
N1680X-1.24Y.2775I-.5145J.6105
N1690X-.055Y.1625
N1700X-.0125Y.1575
N1710X.005Y.175
N1720X.05Y.145
N1730X.08Y.135
N1740X.085Y.0675
N1750X.0775Y.0875
N1760X.0425Y.0325
N1770M3
N1780X-.4925Y-3.235
N1790M4
N1800X-.085Y.02
N1810X-.14Y.07
N1820X-.115Y.1025
N1830X-.0875Y.1175
N1840X-.065Y.1725
N1850X-.035Y.125
N1860X1.215Y.1125I.6465J-.3665
N1870X-1.34Y-.43I-.5755J-.511
N1880X.0375Y.1575
N1890X.04Y.065
N1900X.0425Y.07
N1910X.0325Y.075
N1920X.0225Y.0325
N1930M3
N1940X-2.4025Y-.7225
N1950M4
N1960X-.15Y.015
N1970X-.1525Y.055
N1980X-.15Y.09
N1990X-.125Y.105
N2000X-.005Y.09
N2010X1.39Y.28I.7535J-.1525
N2020X-.0775Y-.965I-.68J-.4315
N2030X-1.3125Y.49I-.5535J.5205
N2040X.0125Y.08
N2050X-.0025Y.1525
N2060X.0425Y.1175
N2070M3
N2080X4.0475Y-2.675
N2090M4
N2100X-.12Y.1175
N2110X-.13Y.18
N2120X-.06Y.1375
N2130X.025Y.07
N2140X1.1925Y.015I.602J-.464
N2150X-.1525Y-1.13I-.607J-.4935
N2160X-1.15Y.9375I-.438J.6365
N2170X.065Y.0925
N2180X.05Y.1
N2190X.0125Y.0125
N2200M3
N2210X-1.8125Y-2.495
N2220M4
N2230X-.1375Y.075
N2240X-.145Y.105
N2250X-.1225Y.1175
N2260X-.095Y.11
N2270X-.0925Y.14
N2280X.0025Y.0475
N2290X1.0575Y.32I.682J-.3475
N2300X.3675Y-.895I-.397J-.686
N2310X-1.5025Y.21I-.736J.216
N2320X.005Y.1525
N2330X.03Y.075
N2340X.025Y.0325
N2350X.035Y.1325
N2360X.0825Y.1175
N2370M3
N2380X.6225Y-2.95
N2390M4
N2400X-.005Y.1825
N2410X-.03Y.15
N2420X-.0525Y.1725
N2430X-.1075Y.265
N2440X-.115Y.1525
N2450X-2.1075Y3.8025I5.5795J5.5775
N2460X2.84Y8.0625I7.75J1.8015
N2470X2.015Y1.145I4.7055J-5.9355
N2480X.2075Y.0825
N2490X.405Y.1325
N2500X.1Y.02
N2510X.025Y-.0175
N2520X.005Y-.41
N2530X.005Y-.405
N2540X.005Y-.415
N2550X.005Y-.4125
N2560X.005Y-.4175
N2570X.005Y-.825
N2580X.005Y-.4125
N2590X.005Y-.8175
N2600X.0025Y-.3
N2610X.0025Y-.3125
N2620X.005Y-.6325
N2630X.0025Y-.315
N2640X-.005Y-.155
N2650X-.0575Y-.165
N2660X-.0725Y-.1625
N2670G3X-.43Y-1.695I2.254J-1.474
N2680X.405Y-1.215I2.528J.1675
N2690X.085Y-.14
N2700X.0625Y-.14
N2710X.0425Y-.15
N2720X.01Y-.145
N2730X.005Y-.58
N2740X.005Y-.4
N2750X.005Y-.53
N2760X.0025Y-.295
N2770X.005Y-.4
N2780X.0025Y-.2975
N2790X.005Y-.415
N2800X.0025Y-.3075
N2810X.0025Y-.3075
N2820X.005Y-.415
N2830X.005Y-.6075
N2840X.005Y-.41
N2850X-.0025Y-.6925
N2860X-.125Y.0175
N2870G2X-2.8125Y1.435I2.2425J7.8695
N2880X-.53Y.4475
N2890X-.065Y.0325
N2900X-.08Y.1275
N2910X-.095Y.0975
N2920M3
N2930X7.655Y13.9475
N2940G98
N2950M30
