Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 08-09-2009, 10:17 AM
Ashish B's Avatar
Ashish B is on a distinguished road
Question Programming for HMC
hI
I been a CAM programmer on Vertical machining centre....
I was reluntant to know how CAM Programs are generated for Horizontal machining centre...I have never ever heard in my past about a CAM software for HMC...
Or is that so that the same programs ( made for VMC ) work for Horizontal machining centre...
Old 08-09-2009, 11:54 AM
atvracer is on a distinguished road
at my shop we program the same but VMC we use A and on the HMC we use B for the 4th axis
atv
Old 08-10-2009, 12:38 AM
Ashish B's Avatar
Thanks buddy......
Had a minor doubt.....how much time it takes to align the part on a HMC as compared to VMC....???
As in HMC the operator has to fight against alignment as well as the crane whcih will hold the part...
But in VMC U need to only fight against alignment...that's it...
Ash.
Old 08-10-2009, 08:08 AM
ours smaller HMC have 2 or more pallets so one is cutting the other is outside swapping parts and with a HMC there no chips and coolant bath to fight it goes down to the bottom of the machine not on top of the part like on a VMC. I do like the HMC better then i do a VMC most of the time there are a few parts we make that i can't use the HMC its all about fixtures and type of parts like if i have a plate say 12x12x.5 " that needs holes bored a VMC would be easier to setup if had a 6x4x5 block that need a deep pocket milled I like a HMC our bigger HMC are big we put up 15,000 lb chunks of steel on it
Old 08-11-2009, 02:31 AM
Ashish B's Avatar
Question
Ok....
As u are used to both VMC & HMC, i guess u would be correct person to answer........
For eg..if you have a same part to be machined.....
What time u will require to setup on a hmc as comparision to VMC....the only factor is what i refer to is the setup time.........
As u have to fight against gravity ( or adjustment on crane ) as well as dial indicator , as compared to VMC wherin u just need to fight with dial readings....
I don't refer any setting ( like on tombostone ), i refer to a setting with help of 2 dowel holes....
Ash
programming help fokusco Haas Mills 4 11-14-2008 10:00 AM
Programming suhas more Employment Opportunity 0 10-28-2008 02:22 AM
CAM programming mallinathan Diemaking and Diecutting 0 10-19-2008 12:08 AM
Cnc Programming Course millmonkey1 G-Code Programing 0 02-20-2008 02:54 PM
g&l programming abigg General CAM Discussion 3 10-01-2007 02:46 PM
