Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 07-28-2009, 10:14 AM
cjjonesarmory's Avatar
cjjonesarmory is on a distinguished road
What program builds 3D Model from GCode?
A couple months ago, I saw that one of my software packages was able to reverse engineer a 3D Model from GCode, except I can't seem to remember which program I saw that could do that. I think it was BobCad. I have V21, but also viewed the demo for V23.
It would take GCode, simulate the machining process, and give you an actual 3D Model FILE (the file being the important part). I know all of my CAD/CAM programs simulate the machining process, but there was one that would construct an actual file (like an STL or something).
Does anyone know if it was BobCad, and how to do this? If it wasn't BobCad, is there another program that will do this?
He is more machine now than man.....
Old 07-28-2009, 02:13 PM
Torsten's Avatar
Torsten is on a distinguished road
A Solid G-code Verification Program will give you a solid model of the Part.
Not likely a perfect replika of the original because of the way it is constructed it wont allow you to do much with it in terms of modification.
But probably good enough for a mockup.
Old 07-28-2009, 02:33 PM
Your post led me to a better Google search and I see a lot of "GCode Backplotters" is a "GCode Backplotter" what I need?
Looking for DIY 5 Axis builds turbostang Vertical Mill, Lathe Project Log 12 10-27-2009 10:13 AM
New Machine Build- Mullet Builds a 3 Axis CNC Mullet DIY-CNC Router Table Machines 10 07-22-2009 08:16 PM
Newbie- Longer Z axis builds? rbs DIY-CNC Router Table Machines 2 06-02-2009 06:11 AM
TRON cnc re-builds jensn DIY-CNC Router Table Machines 0 12-17-2007 06:11 AM
cheap bitmap to gcode program balsaman DIY-CNC Router Table Machines 29 07-28-2003 01:04 PM
